Old 02-10-2015, 10:00 AM   #397
robkay
Drives: Hatch
In my case it was exactly the slushy/salty scenario that seemed to trigger the problem. I am happy to say that even though I only did the rear connectors last April, so far, my indicators have not come back on since last July. The ABS has kicked in a couple times, so I know it works. Now, it is probably accurate to say that, this winter, we have not done as much driving in slushy weather as the winter before. Of course, after I cleaned the rears the indicators didn't go out for 3 months. Did my cleaning actually fix the problem, or was it somewhere else and it finally dried out over the Summer? Who knows. In any case, I'm hoping the problem does not resurface as I do not need that expensive repair. If it happens again I'll clean the fronts and if that doesn't fix it I'll probably just live without the ABS.
robkay is offline   Reply With Quote
Old 02-10-2015, 11:47 AM   #398
IllusionX
Drives: 07 Yaris Sedan Aero
I was looking at digging up this thread. Mine came on a while ago during the ice storm in January. But it quickly turned off as weather warmed up.
I plugged the TechStream tool and it does show rear left sensor issue. I haven't erased it and ABS is working. But the issue I am having now is the rear right wheel locking up.
I haven't seen the ABS light since then, but I still experience rear right wheel locking up, throwing the car to the left until the rest of the ABS system straightens the car...
Old 03-23-2015, 09:07 AM   #399
Logen9Fingers
Drives: 2007 Yaris sedan
Thank you everyone here. You all have helped me fix my dreaded ABS and Brake light issue. Here is what I went through.
Issue:
ABS and Brake light come on and off. It happens randomly with no Rhyme or reason, and would stay on most of the time. The ABS also kicks in when I roll to a stop; it only happens if I am going slow.
Fix:
Removed back 2 wheels (1 at a time). Sprayed cover to speed sensor harness with WD40. Used flat head screw driver to remove the cover. Cleaned cover with WD40. Disconnected harness from speed sensor (used same screwdriver to gently pry it off). Sprayed dielectric spray inside both ends. Reconnected everything.
So happy I did that this weekend before it started snowing again.
Logen9Fingers is offline   Reply With Quote
Old 08-16-2015, 06:37 PM   #400
trojjanhorse
Drives: 2007 Yaris LE
Hi everyone
I too own an OBD II bluetooth adapter and like many it did not reveal any fault codes.
I jumped 4&13 and here's the flash pattern i witnessed:
3.3..3.4..3.9..94...repeat
The dots are supposed to be seconds between flashes.
Anyone know what these flash patterns mean?
Thank you.
trojjanhorse is offline   Reply With Quote
Old 08-16-2015, 09:35 PM   #401
33 - Right Rear Wheel Speed Sensor Signal
34 - Left Rear Wheel Speed Sensor Signal
39 - Foreign Object is Attached on Tip of Rear Speed Sensor LH
94 - Control Module Communication Bus OFF
Old 08-18-2015, 12:24 AM   #402
trojjanhorse
Thanks Scott. I opened up the two small harnesses that cage the rear sensors and sprayed contact cleaner. The wires seem fine to me on inspection. I think my problem is a bit more deep seeded. This all happened post rust-proof. Do you have any idea or advise as to what I should do next?
Thank you
Old 08-18-2015, 07:03 AM   #403
I would go back to your undercoating people, as it sounds like they coated the rear sensors.
Old 08-18-2015, 02:00 PM   #404
trojjanhorse
Hey Scott,
Thanks again for replying so quick. Always appreciate your words of advice. I live in a different city now and visiting the under-coaters is not really an option for me anymore. Would I have to remove the rear wheels and get intimate with the ABS sensors? Is there a guide/manual that shows how to remove the rear sensors? I got the outer shell open but I don't want to tinker with the wires unless I know exactly how to remove the connectors.
Thanks
Old 08-18-2015, 08:31 PM   #405
Originally Posted by trojjanhorse View Post
Hey Scott,
Thanks
You have to completely remove the rear hubs to get to the sensors and special tools are required to remove the sensor from the hub to get to the business parts.
Name:  Yaris - Rear ABS.jpg
Old 01-13-2016, 05:53 PM   #406
wes369
Drives: 2008 Toyota Yaris Sedan
Disabiling the bloody ABS
Hi There,
Yes... Same ABS issue with my 2008 sedan. I have decided to just disable the Bloody ABS and go back to good old pumping the brakes on the ice.
To disable bloody ABS I went to the fuse box beside the battery and removed the fuses. There are two of them. A 50 amp and a 30 amp. ABS1/VSC1 and ABS2/VSC2. The map on the fuse cover will show you there locations.
As far as the bloody annoying lights, i simply used some black electricians tape and masked it over top of the lights. Mickeymouse i know but at least my eye isnt drawn to them anymore. And it doesnt even look half bad really. Feeling less resentful to that those bloddy corporate shills wont stand behind there obviously flawed ABS system. Oh the shame of it all. No surprise to me though.
If I'm feeling less lazy i will pull off that dashboard molding and get behind the bloody thing and pop those bloody lights out too.
Only downside is that the E-Brake light will no longer be visible in case i leave it on by mistake. I get a warning beep when that happens so it is all good on my end.
Hope that is helpful.
Wes
wes369 is offline   Reply With Quote
Old 01-13-2016, 09:40 PM   #407
IllusionX
I've had the ABS warning light come on last year. First time after 8 years of abuse. The problem seems to be salt is able to find its way into the connector, and make improper contact with the ABS sensor on the hub. Filled it with dielectric grease and it never came back again.
Sent from my ONE A2005 using Tapatalk
Old 01-16-2016, 10:10 AM   #408
LeetViet
Drives: 07 Yaris 4DR
My ABS and ! light came on this week. I took it to the dealership to diagnose and they came up with rear left, and front right. I said hold off on the repair (and they wouldn't inspect my rear right for some reason). Picked the car up, and the light has been off. Took it to another mechanic I trust, and he said to drive it as-is until the lights comes on again.
LeetViet is offline   Reply With Quote
Old 04-02-2016, 12:26 PM   #409
LeetViet
My ABS and ! light have been coming on more often. I took it to a small mechanic I trust to diagnose.
ALL my sensors showed up on the history, which led my mechanic to think it wasn't a sensor problem. The mechanic cleared the codes, and went for a drive. My right rear sensor came on immediately. I'm going to drive it for a week or so, and go back to see if the other sensors will come up again.
Old 04-02-2016, 01:23 PM   #410
"G"
Drives: 2007 Yaris Hatch
Cars don't fix them selves.
"G" is offline   Reply With Quote
Old 04-16-2016, 10:36 AM   #411
LeetViet
Took the Yaris back to my mechanic. The rear right, and ONLY the rear right, ABS sensor came up on the scan. I'm going to replace the rear right and the harness next Saturday. Hopefully that'll be the end of things.
Old 04-23-2016, 01:57 PM   #412
tmontague
tmontague's Avatar
Is there a reason the mechanic only replaced one sensor? Any of the 4 sensors could cause the issue so replacing one is good, but not if the other 3 are also causing the issue
Old 04-23-2016, 02:47 PM   #413
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
had mine go 4 or so years ago, was told it was $700+ to repair so i pulled off the gauge cluster and covered the lights with electrical tape behind the face. Last year when i replaced my front bearings i noticed a ton of corrosion on the speed sensors.
Really a problem that should have been addressed by Toyota. :(
Edit: never really needed the ABS, just buying some good tires and brakes and my little Yarii can plow through winter like no tomorrow
z0mb13k1ll is offline   Reply With Quote
Old 04-24-2016, 04:10 AM   #414
LeetViet
My ABS and ! light turned off this week with the warmer weather.
Despite that, I went through with replacing my rear right wheel bearing and ABS sensor harness. Cost me about $450. Fingers crossed the issue doesn't return next winter.
