Old 03-24-2015, 05:59 AM   #19
bronsin
bronsin's Avatar
Originally Posted by ectoman View Post
Thank you for the advice I'll try that next time, I already got the tube on albeit a little warped but it's fully snug onto the barbed male end - it won't come off I tried pulling it off it is on there good, so it should hold right?
Go with it! My nail solution is probably wrong. You need THE TOOL and practice to do the install...
Old 03-26-2015, 09:57 AM   #20
ectoman
Drives: 2008 Toyota Yaris (black)
Hi guys I have the Fuel pump assembly put back in but started it several times but I can't get the car to start. Does the Fuel pump assy have to be charged with petrol prior to starting or can it just be simply immersed in the tank and then it would draw the fuel into the device? I'm thinking and dreading buying the whole pump assy, but i think i may have to, especially after i put on that black hose with heat, there may be a vacuum leak and not drawing fuel correctly? Well I guess I'll have to shell out that cash if I want it done right, so much for trying to go the cheap route:(
ectoman is offline   Reply With Quote
Old 03-26-2015, 10:02 AM   #21
ectoman
Post The Tool
Hi Bronsin do you know where I would find this TOOL? If so let me know appreciate your feedback sir.
Old 03-26-2015, 06:22 PM   #22
It is a pretty expensive tool:
http://www.summitracing.com/parts/rn...188aAm4p8P8HAQ
Old 03-26-2015, 08:08 PM   #23
ectoman
Wink Gratitude
Hey thanks again for your rapid responses CT!! By the way do you possess this TOOL?
Old 03-26-2015, 08:36 PM   #24
No. I almost bought one for a project I was working on, but ended up using fuel injection rated hose instead of the plastic tubing, as it is hard to talk yourself into buying a tool that you will only use once in a blue moon.
Old 03-27-2015, 05:59 AM   #25
bronsin
bronsin's Avatar
No. Didnt it work what you did?
MAkes me long for my 74 VW. It didnt need $82 tools to fix the plumbing...
You really dont need to be changing this filter just for the heck of it. Onky if the car doesnt run because the filters FUBAR.
Old 03-26-2016, 09:37 AM   #26
Kirill
Drives: Yaris 2009 1.3 sol 100HP
Hello,
I have Toyota yaris 1.3 vvti sol mmt 2009 (made in France).
Any body knows the part number of the fuel filter and any additional parts that recommended to replace on the way with the fuel filter.
will appreciate any help...
thank you
Kirill is offline   Reply With Quote
Old 03-26-2016, 09:38 AM   #27
Kirill
Hello,
thank you
Old 03-26-2016, 12:07 PM   #28
Originally Posted by Kirill View Post
Hello,
thank you
Toyota only lists the fuel filter as part of the entire fuel sender assembly, so you would have to find an aftermarket filter to replace it with.
The Toyota part number for the whole assembly is: 77024-0D080, but it looks like the cost is over 200 Euros. An aftermarket filter should be less than 40 Euros.
Old 06-15-2016, 08:08 AM   #29
arsenalist1
Drives: Toyota Yaris
I have tried to open this thing but i couldnt, i have taken out the whole tank but still i did not make it.. any other tip?
arsenalist1 is offline   Reply With Quote
Old 06-15-2016, 07:37 PM   #30
There are two methods (without buying the expensive Toyota tool):
1. Beat it off with a hammer and piece of wood. This will damage some of the ribs on the cap, and will be a heck of a workout, but does work.
2. Make a tool, like the picture below. I created this a few years ago and a couple of people on here have had them made, based on my design. I simply took a piece of scrap pipe, cut a piece in half, and welded the cut sections to the main piece. This perfectly catches the ribs on the cap and allows easy unscrewing and tightening of the cap:
Old 06-16-2016, 12:13 AM   #31
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am one of the ones that copied Scott's design. If you do an advanced search for fuel tank tool for posts with my handle I have posted photos with measurements.
Sent from m-o-b-i-l-e
Old 06-16-2016, 12:46 AM   #32
NEexpat
Drives: 2009, auto, 4dr LB
ectoman,
So boiling water isn't hot enough to make the tubing pliable enough to slip over the nipple properly.
Raise the temperature of the boiling water.
Add salt to it.
I think for every tsp. of salt into a quart of water you can raise the boiling temp. 1 or 2 degrees F.
Or or you could try heating some salt in an oven, regular old table salt in an oven proof dish to a set temp, say 240 degrees F. stick the end of the tubing in there for several seconds and try it on the nipple. Do this incrementally so as not to damage the tubing. Test it. It may take a couple of tries raising the temp a bit at a time. That could work without damaging the tubing and getting a proper seat on the nipple.
Of course I have no idea what effect salt or a concentrated saline solution would have on the short or long term integrity of the tubing would be, I doubt it would be anything really, it would only be in contact briefly, so of course, you do this at your own risk.
cheers.
Don't ask how I know this, suffice to say I learned it in college.
NEexpat is offline   Reply With Quote
Old 03-20-2017, 08:09 AM   #33
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
Thumbs down
WTF the yaris has no fuel filter on the firewall like every car has had for decades?
I was thinking of changing the filter and found this.
this is the stupidest thing I ever saw...its in the tank?
wow thats ridiculous.
http://www.yarisworld.com/forums/showthread.php?t=38381
Cartel is offline   Reply With Quote
Old 04-14-2017, 05:16 AM   #34
arclite
Drives: Toyota Yaris Vitz dohc 16v 1.3
Hi, I am a new member, this thread appears suitable for my needs, I have a Yaris Vitz 2003 1.3 L dohc 16v petrol but we have lots of sleeping policemen in our neighbourhood and things do "get a little bumpy" round here. My car started to die, all cylinders stopped firing together. Sprayed around the electrics with water repellant WDxx. Car started but died after a short spell. Started after a while but again died after a short run. Decided to change the fuel filter first!
Any ideas on the part number required to fit this model? What range of models will this part fit? I ask because there is so much 'information' out there some sense of "cross reference" will help me avoid buying the wrong part.
Many thanks for any answers to my request for help. I've gotten attached to this steady car and I do not want to let go while I know I can fix this problem.
arclite is offline   Reply With Quote
Old 02-08-2023, 07:07 AM   #35
ex-x-fire
Just a tip for anyone wanting to push fittings on plastic tubing, you can use a caulk gun and a wooden clamp to press them on.
Old 02-24-2023, 09:45 PM   #36
mirageman
Drives: 2009 yaris
I am happy for the revival of this thread, I have completely forgotten that I probably should change the fuel filter on my 2009 which has over 250,000 miles on it. I am quite certain I will find a way to get a filter in there, but my concern is getting a reputable filter that fits a 2009 1.5 American model. I saw a Herko brand on ebay but after multiple emails getting NASA (Never A Straight Answer) answers to very basic questions, I gave up and forgot about it. I am concerned that going with a no name brand from a relatively new company, I will be left with a not-up-to-par filter with a poorly fitting housing. I am concerned about the filter media itself. I don't want to find out that it disintegrates or collapses on itself. Has anyone done this on a 2009?
EDIT: What I mean to say is, I'm a cheap guy. I'm NOT buying a 200 buck fuel pump setup to replace what should be a $30 filter. I wouldn't risk getting a new pump that might fail sooner than the oem that's currently in there. I'm looking for someone who might know a decent aftermarket filter that I can make work in my oem. Interesting on getting an 07 pump to use that cheap filter, but would rather keep my pump, you know? :-) Maybe I could somehow dig out the old filter media, leave it empty and attach an oldschool filter somewhere on the firewall. THAT would be cool.
second edit: I think I'm going to have to do this twice. My car is an 09, but made in August of 08. Apparently there are differences between 08 and 09, and sometimes my luck is good... I'm going to remove my pump soon disassemble it and take photos and put it back and just buy a filter and do it again when it comes in. I gotta clean out my back seat, anyway...
mirageman is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Replacing fuel filter duke_afterdeath Middle East 28 07-12-2010 04:26 AM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
