Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 05-01-2015, 08:37 PM   #1
banny
Drives: YarisTS2001
Engine response
Hi people im new to the forum and got a quick question : sometimes my car feels very responsive and sometimes it feel very sluggish anybody else ever get that ? And what could it be?
banny is offline   Reply With Quote
Old 05-01-2015, 08:38 PM   #2
banny
Drives: YarisTS2001
51 plate yaris tsport
Old 05-23-2015, 05:33 PM   #3
aspro
Change in temperature will change the performance of the engine. Bad gas will do the same. That or its just in your head :p
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 05-23-2015, 09:05 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
electronics, revs, etc. Drive by wire doesn't help.
Colin Chapman disciple
Old 05-27-2015, 02:11 AM   #5
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
All of the above could be true. The ecm also learns your driving habits, so drive it how you want it to respond. ��
ArmstrongRacing is offline   Reply With Quote
Old 06-10-2015, 04:38 AM   #6
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Really ???
I find mine unresponsive and sluggish too sometime. esp when engine still cold.
Footwear also makes a difference.
JudgeM is offline   Reply With Quote
Old 06-15-2015, 05:49 PM   #7
justjesus
justjesus's Avatar
Drives: 2008 Liftback
if you run a Scangauge or similar, compare your Intake Air Temp when it's running sluggish and when it's running good. On my stock yaris, the car feels better with lower IAT. (hence why a cold air intake could be good)
Old 09-03-2016, 05:04 AM   #8
Tamer
Tamer's Avatar
Drives: BMW
Tamer is offline   Reply With Quote
Old 09-04-2016, 06:31 PM   #9
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
What abou disconnecting the battery to reset the ecu. After a few minutes, connect the battery. Start the car and let it idle for 10 mins. After that, drive how you want it to learn, enjoy!
Captain Yaris is offline   Reply With Quote
Old 09-05-2016, 12:33 PM   #10
froger
Drives: 08 yaris 1.8 dual vvti 5sp
Originally Posted by JudgeM View Post
Really ???
A cold engine tends to over fuel due to the cold air.
Cold air is more dense and harder for fuel to vaporize due to the cooler engine temperature.Fuel in liquid form does not combust,this creates poorer response when the engine is still cold.
There are number of factors, temperature , altitude and humidity seems to be the big ones,I find when my engine gets heat soaked or coolant temperature goes above a certain temperature the car tends run sluggish.Also on warmer days car runs bad this is all due to the poor air density.
froger is offline   Reply With Quote
Old 09-05-2016, 02:01 PM   #11
rabbito
rabbito's Avatar
just like aspro said....temperature change cause major performance issue..i live in thailand 40c/104f with jungle weather and humidity...im doing 0-100 high 9 to 10 sec with all the mods....sucks balls...😥😥😥
only time of the year is january which is cool for like 2 weeks(22c/71f) with no humidity....man..im like flying on the highway 😂😂😂
Cosmetic: Toyota red emblem
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Can I change my yaris engine from 1.3L to 1.8L Rami yaris Performance Modifications 9 06-11-2012 10:21 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
