Old 06-18-2015, 11:12 AM   #1477
lormagni
Drives: Toyota Yaris 1.33 SR
Japan racing JR3 16x7" with Bridgestone Ecopia EP25 (195/50 r16). Sorry for the dirty car :D
lormagni is offline   Reply With Quote
Old 08-02-2015, 04:46 AM   #1478
CanadianYaris
Drives: Future 2008 Yaris Hatch
Originally Posted by WorkTL View Post
Attachment 55543
Attachment 55544
Attachment 55545
Attachment 55546
SSR mk III
15x8 +13 front
15x8 -0 rear
155/60R15
Tein coilovers
-3° camber front
-5° camber rear
THIS IS THE EXACT FITMENT I WANT! Only i may go with 15x7s with less offset. Do you just have -5° realcamber shims in the back? How did you get your fronts to -3°? Sorry im new to camber
CanadianYaris is offline   Reply With Quote
Old 08-04-2015, 02:55 AM   #1479
AOR 1-1
Scraper
Drives: '08 Yaris RS 5-Door
I've got some BC racing coilovers inbound for my 08 hatch, starting to look at new wheels. Current choices are either 17x9 ET25's or 17x8 ET33's. Thoughts? What would i have to do to fit these?
AOR 1-1 is offline   Reply With Quote
Old 08-04-2015, 04:25 PM   #1480
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
It depends what look are you going for. Are you looking at going the stanced route? If so, the 17x9 +25 setup will definitely poke out of the fender. The 17x8 +33 will also poke out but to a lesser degree. If you want the wheels to sit flush with the fenders then you will need a set of camber bolts / shims to dial-in some negative camber. Also, you will need to run stretched tires or do some fender rolling/pulling for clearance when going really low. Also, on most coilover setups for the Yaris, the rear will tend to not go low enough where you may need a set of shorter springs.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 08-04-2015, 05:24 PM   #1481
Rigaud
Drives: 2009 Yaris
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 08-05-2015, 05:43 PM   #1482
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
All nice rims n wheels, for the most part. Make sure to try and get a good tire, V or Z rated as they are sticky and grippy. The V should be sufficient. I was glad I did this morning 5:15 am, tight road, fallen tree around a bend in my lane, and a car and a full logging truck right at me simultaneous. I tried to stop, ABS kicked in, so swerved left (into oncoming traffic), then right and as I went right, I looked up at logs briefly, while making sure I didn't go off road to the right whilst turning back. So, Guardian Angel check, Michelin V rated Premiers, check. wOw. 12.5 hours later and I am happy to still be here. Some scratches from tree on right side, but, first look only three, and just scratches. Will look tomorrow when I catch my breath. Anyway, to reiterate my point, do not be cheap on tires when buying nice rims please. It does pay off sometimes. That and a guardian angel
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 08-05-2015, 11:19 PM   #1483
AOR 1-1
Scraper
Thanks for the advice, will post pictures once I get the coilovers fitted and the current wheels spaced.
Old 08-09-2015, 02:23 PM   #1484
alfredo
Drives: yaris belta
Please post pics of your Yaris with aftermarket rims here
Xxr 962 18x8.5
tire Toyo 215/35/18
Lower springs Tein
alfredo is offline   Reply With Quote
Old 08-11-2015, 08:41 AM   #1485
ardianpradana
Drives: White Yaris J M/T
Send a message via MSN to ardianpradana
from Indonesia
Enkei RC-T4
ardianpradana is offline   Reply With Quote
Old 08-11-2015, 10:30 AM   #1486
KTS
KTS's Avatar
Drives: Vitz RS
2007 Vitz RS
16x7, +42 offset, 205/50/16
Dupli-Color HWP105 Bronze High Performance Wheel Paint
KTS is offline   Reply With Quote
Old 08-19-2015, 04:48 AM   #1487
AOR 1-1
Scraper
Was gonna wait until I got my coilovers, but what the hell.
Tein S.Tech Springs
205/40 17x7.5 ET43
Unknown wheels, were on the car when I got it.
File Type: jpg 10721308_820212431352012_1648813277_n.jpg (40.7 KB, 822 views)
Old 08-19-2015, 10:49 AM   #1488
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Looks great.
Do you ever get any tire rub?
Old 08-19-2015, 05:05 PM   #1489
AOR 1-1
Scraper
None at all, unless I'm totally deaf.
Old 08-19-2015, 05:39 PM   #1490
ern-diz
ern-diz's Avatar
Interesting. I just lowered mine with S Tech's and am running 205/40/17 and I get a little tire rub in certain scenarios.
Old 08-22-2015, 01:07 PM   #1491
2o6
Hiya! Just added these Wheels from CL idk the brand but they look good and were cheap
2o6 is offline   Reply With Quote
Old 08-24-2015, 11:28 AM   #1492
ern-diz
ern-diz's Avatar
Old 08-24-2015, 12:07 PM   #1493
tmontague
tmontague's Avatar
Nice rims, where'd you pick those up from and do you know the specs? I'm looking for rims just like those
Old 10-15-2015, 12:43 AM   #1494
24boosted
Drives: 09 yrs
15x8.25 +15 Drag DR54 on 195/50.
24boosted is offline   Reply With Quote
