Old 07-16-2015, 04:32 PM   #1
mf4361
Drives: Yaris Sedan
Help needed! Car won't start
Hello and help, I have a canadian 2007 Sedan.
My car won't start in the afternoon, not even a sound of cranking. The dash faintly flickers. It was fine this morning and lunch time and no sign of any problem.
I checked the battery it's showing 12.4V, but measuring from the interior 12V power source shows 4.7V.
It did shows some weird moments where it doesn't responds when i turn the key (not even lights). But back to normal after I take out the battery terminals and put it back
I am guessing the starter problem? I havn't got a chance to check the starter fuse but I will soon (I have to leave it in the local coffee shop and have my colleague give me a ride :()
mf4361 is offline   Reply With Quote
Old 07-16-2015, 05:08 PM   #2
valchrist90731
Drives: 2007 toyota yaris sedan
Do you have acid eating the battery cables?
If this happened get new cables or clean the old ones with arm and hammer baking soda then cut and reclamp the cables. Very easy fix.
Measuring volts from interior where?
Well not sure but i think it is acid build up..
valchrist90731 is offline   Reply With Quote
Old 07-16-2015, 07:47 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
First guess would be a bad battery. Be aware that it is possible for a battery to show 12+ V on a volt meter and still be "dead". A load test would be able to determine if that is the case in this instance. How old is the battery? Anything over 4 years I would just buy a new one and not even bother getting it load tested.
NYC-SE is online now   Reply With Quote
Old 07-16-2015, 08:37 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If thats the original battery its probably time for a new one, however i;d do a thorough cleaning of terminals and connectors first.
Have Yaris will travel..
Old 07-16-2015, 10:00 PM   #5
mf4361
Drives: Yaris Sedan
Solved by my colleague that noticed that the +ve terminal is not firmly contacting and was arcing. (It's not the OEM batt) I did cleaned of some acid residue but I guess that wasn't enough. Anyway, it's normal again. Thanks for all your comments!
Old 07-16-2015, 10:24 PM   #6
NYC-SE
NYC-SE's Avatar
Glad that it was something simple.
Old 07-17-2015, 12:02 AM   #7
valchrist90731
When you fully clean off the acid from your cables use water and baking soda. Use a tooth brush.
Once wiped clean put some Vaseline on it where acid usually builds up. This will keep the acid from forming again for a Long time.
Please do it thoroughly the first time.
If cleaned properly this will help not damage other important parts inyour vehicle.
Acid eats and destroys everything including you wallet.
Save yourself because now you know.
Acid build up can damage important car parts. Results can range in the thousands of $$$.
Some cars air conditioning pipelines can be damage is an example.
But that's just an example and really depends on the cars set up.
Old 07-17-2015, 07:29 AM   #8
tmontague
tmontague's Avatar
I'd recommend covering the terminals in dielectric great. I've done this for years and have no corrosion or acid at all.
Old 07-17-2015, 12:11 PM   #9
mf4361
Drives: Yaris Sedan
Thank you for all the advice. I will do that over the weekend and see how it goes
Toyota Yaris 2007 car wont crank no start aamrkhan DIY / Maintenance / Service 0 01-19-2015 10:31 AM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
Zefoxe - Photo Scavenger Hunt Zefoxe Photo-Video-Media Gallery 0 03-02-2009 10:23 PM
