#19 |
Mr. 155 and climbing
Some info if you considered the Prius Piston Swap:
- Take a notch from the top of each piston due to some knocking in the yaris who had my prius pistons, other than that you just open, drop them in and run it - 13.1:1 compression! Like always your gains come from doing changes and or multiple mods. Open up exhaust, intake, bigger throttle body, port intake.Need fuel management too at this point to tune. From what I know and believe you don't require bigger injectors but a tune at a dyno would determine that. Some have shown gains with dyno numbers at 132whp so around 145hk at the crank. No turbo. - Tune with something like the AEM FIC, Greddy eManage, APEXI Neo, etc. Some videos of a car equipped with the swap: Angelos Prius Piston swapped Yaris
#20 |
this is tempting also....
When you say "notch", what is suppose to be notched to avoid damage to what?
#21 | |
Sent from my SCH-I545 using Tapatalk
#22 |
![]() Drives: white 2015 1.5L yaris Join Date: Mar 2015
When it comes down to the running though do i need to go aftermarket with the ecu? Or is the stock one viable?
Eyeing up an exhaust system atm |
#23 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Someone is selling their Haltech here: http://www.yarisworld.com/forums/showthread.php?t=54910 If you plan on keeping the 1NZ engine, i'd also suggest looking into lightweight pulleys or even a flywheel. It might not make any HP but it will certainly help with acceleration and help make the car "feel" faster.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#24 |
Prius pistons will require a piggyback otherwise you are throwing money out the door.
#25 |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
When I built my last motor I bought a Prius Piston from a Prius C 13.4:1cr just to see how it compared to the Yaris parts.
You don't need to notch the piston, but there are a few thing you up running into. The intake cam will go from being a non interference part to a interference part, so you'll be limited to the cams you can run, and its very likely you'll need to run 93+ octane fuel.
2014 BSpec Divisional Champion |
| Tags |
| turbo supercharger kits |
