Old 08-18-2015, 11:13 AM   #1
tmontague
tmontague's Avatar
need some guidance
Hey guys,
As you can see in my signature i've made some performance mods in the past month. I will be installing a short shifter from MI soon but that's it for this year.
Next spring I want to add a few other mods. I'm thinking the 1zz TB and intake manifold (if one can still be purchased?). I also want to pick up some rims (195 wide 15" diameter). Obviously neither is cheap other than the TB.
What my question is, what is the next best cost/performance mod I should do? I am interested in improving low end torque and keeping the gas mileage good and fun to drive. So far i'm impressed w/ the mods i've done.
Old 08-18-2015, 11:43 AM   #2
Lightweight crank pulley.
Old 08-18-2015, 12:01 PM   #3
LTHatch
Drives: 2013 Yaris Hatchback L
Best mod for the money while keeping MPG and improving acceleration, removing weight(if that is something you're willing to do of course). I removed around 125lbs, first and second gear acceleration improved.
For the 1zz TB, you can do what Kou did here http://www.yarisworld.com/forums/sho...+throttle+body It by no means replaces a proper intake manifold like MI or even tooter, but its budget and it definitely wont hurt performance either.
LTHatch is offline   Reply With Quote
Old 08-18-2015, 01:13 PM   #4
tmontague
tmontague's Avatar
The lightweight pulley will be done before the intake mani for sure. I'm just wondering if the 1zz TB is worth it with the stock manifold? Its a realitvely cheap and easy mood to do so iif there is a bit of benefit w/ the stock manifold then i'll definitely do it.
Honestly as much as rims are mostly aesthetic i'm thinking i'll pick those up and do a manifold last. Now just to find a good place in canada for cheap rims...
I won't be able to shed anymore weight as I occasionally put people in the back seat so removing that wouldn't be practical for me. Maybe down the road but not for now
Old 08-18-2015, 01:38 PM   #5
KTS
KTS's Avatar
Drives: Vitz RS
the 1zz tb is worth it. There is a noticeable improvement in throttle response. Ensure you do the chip swap and/or adjust the idle screw. Then have patience and allow the ecu to learn the new tb. Take a drive and enjoy the new throttle response.
KTS is offline   Reply With Quote
Old 08-18-2015, 02:08 PM   #6
tmontague
tmontague's Avatar
What's the benefit of narrowing the intake hole?
Old 08-18-2015, 02:21 PM   #7
kijiji
Sadly, that is your only choice for 'cheap' in Canada.
Old 08-18-2015, 02:43 PM   #8
tmontague
tmontague's Avatar
kijiji
That's what i was afraid of. I going to get a price quote I I winter from tire 23 which is place buddies have referred me to. If its crazy expensive then i'll get some shipped to my po box in the states.
Kijiji is tough because I want to go with a wider offset to get the wheels closer to the fenders
Old 08-18-2015, 03:46 PM   #9
http://www.kijiji.ca/v-tires-rims/mi...ationFlag=true
Price you want, offset you want, weight you want. Single drilled to boot! And in Mississauga.
Old 08-18-2015, 03:49 PM   #10
tmontague
tmontague's Avatar
Thanks for the link!
I was aiming to get gold rims, but depending on what new rims would cost I may have to scrounge for used. Anyone have any idea what 4 new 15" rims would sell for at 7" wide?
Old 08-18-2015, 03:51 PM   #11
That's like asking 'What will it cost me to buy a car with 4 wheels and runs on gasoline?'
Old 08-18-2015, 03:56 PM   #12
tmontague
tmontague's Avatar
True, i'm just curious as to what others have paid
Summer blend must be here: averaging 44.4 mpg on current tank (1/3 of a tank so far) matti Fuel Economy Forum 25 08-20-2013 08:53 PM
11 disappearing car features (manual transmission and hand-crank windows listed). matti Off-topic / Other Cars / Everything else Discussions 14 07-07-2013 08:45 PM
backwards fuel economy? Golddeenoh Fuel Economy Forum 14 05-27-2013 11:30 PM
Speakers, need guidance. AlexNet0 In Car Entertainment + Electronics (audio / video / alarm) 16 06-18-2011 01:14 PM
need guidance for the compustar 2W900FMR install vten In Car Entertainment + Electronics (audio / video / alarm) 7 05-20-2009 09:09 PM
