Old 12-04-2015, 12:10 AM   #1
SirDigby
Drives: 2007 yaris 3 door
Stupid Seatbelt!
this stupid seatbelt is pissing me off!
does anyone know if there is a way to adjust this thing so it stops rubbing on my neck? I have a hard time believing that this is the position small Asians prefer to have their seatbelts, it'd be rubbing on their foreheads. are they repositioned for the USDM?
gurr!!!
Old 12-04-2015, 12:50 AM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
where the belt attaches to post by your head it can be adjusted down. squeeze and pull down
Old 12-05-2015, 12:24 AM   #3
SirDigby
what? your crazy. don't you think that's the first thing I looked for...
I can't believe there is not an adjuster...
Old 12-05-2015, 07:45 AM   #4
bronsin
bronsin's Avatar
Mine has one.
Correction: my wifes CAMRY has one. Mine does not.
Old 12-05-2015, 08:11 AM   #5
Post a pick of your b- pillar attachment point. Nobody is going to believe you don't have an adjuster.
Old 12-06-2015, 01:44 AM   #6
SirDigby
here's angle #1
here's angle #2
do you think I can find a pivoting one in the junk yard? have you had your b-pillar off? do you know how the adjuster is attached? I guess I could go pull it apart and check it out....
Old 12-06-2015, 08:19 AM   #7
The service manual shows that all sedans and 5 door liftbacks have the adjustable ones and 3 door liftbacks do not. The B pillar cover area is different one 3 vs 5 door, so you wouldn't be able to grab a 5 door one to use to convert.
Old 12-06-2015, 10:50 AM   #8
Wow, didn't realize that about the 3dr. How ludicrous not to have incorporated an adjuster.
I'm sure plenty of 3dr owners read this thread and never bothered to respond. That's a YW fail for sure.
Old 12-06-2015, 01:48 PM   #9
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Owning a 3 door myself, I dismissed the comment about the adjuster because I had no idea any model had them. Thought the guy that posted that was confused lol. Never dreamed they'd make the 3 door different in that regard.
Old 12-06-2015, 02:27 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
Having owned an "07 3-door until just a week ago, I never felt the need to adjust the seatbelt and just assumed all models had no height adjustment.
I wonder if my '14 5-door has a height adjuster? I'll have to check later.
Old 12-06-2015, 03:43 PM   #11
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
My 2014 SE does NOT have height adjustable seat belts. I would assume that would be true for all 3rd gen Yarii.
Old 12-06-2015, 05:07 PM   #12
kimona
kimona's Avatar
Yup, no height adjustment for the seat belts on my 2014 LE... and thankfully I don't need that feature.
Old 12-08-2015, 11:32 PM   #13
SirDigby
i'm taller that the average Asian. I don't understand why it's so high. i'm going to have to pull it apart and see if I can weld a different mount in to drop this thing like 3 inches. it can't be good to crash and have this thing rip my neck open...
Old 12-08-2015, 11:47 PM   #14
I'm right about the height of the average Asian, which is probably why I find the 3 door seatbelt height to be comfortable.
You may be able to simply obtain the adjustable anchor (73200-52050-B1) and it's cover (73135-52020-B1) and cut the hole in your B pillar cover to let it slide up and down:
My seatbelt alarm won't shut off. JohnBeske DIY / Maintenance / Service 1 08-01-2014 10:42 PM
Rear seatbelt buzzer? brendan Third Gen Yaris General Discussion 0 07-19-2013 07:26 AM
Takata Racing Seatbelt 33lam Australia 0 09-02-2010 09:41 AM
Two stupid questions.... very stupid... Blowtorch General Yaris / Vitz Discussion 26 05-08-2009 01:06 AM
Seatbelt warning annoyance! asa805 General Yaris / Vitz Discussion 5 06-30-2006 08:06 PM
