Old 02-22-2016, 02:39 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
mis-aligned steering wheel
The car is 3 weeks old with only 150 miles
I'd guess it's ~2-3 degrees to the left when driving on any smooth, flat road
none of my other cars are this way
anyone know what the spec/ allowed deviation from center is?
I expect the dealer mechanic to say it's normal
drives me nuts!
Old 02-22-2016, 04:17 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
That looks significantly off to me. No way the dealer can claim it as "normal".
Not to be rude but did you not notice this when you test drove the car?
Old 02-22-2016, 04:45 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Oh, man, that would tap into my OCD like no other.
Old 02-22-2016, 07:53 PM   #4
Definitely not normal.
Old 02-22-2016, 08:10 PM   #5
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Best case scenario, you just need an alignment. Have you gone over any deep potholes lately? How about bumps or dips at an angle? Any weird noises heard in the first 150 miles?
Old 02-22-2016, 08:16 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Alignment is covered under warranty for up to 15k so drive down and have it done
Sent from my SM-N910W8 using Tapatalk
Old 02-22-2016, 09:36 PM   #7
justanotherdrunk
Drives: 2016 SE
no pot holes/ curbs hit - didn't notice since the car has barely been driven
the car drives perfectly straight
just the steering wheel not aligned properly
to the dealer tomorrow
Old 02-23-2016, 12:28 PM   #8
apmatzen
apmatzen's Avatar
Drives: Toyota Yaris 2015 1.0VVT-i T2
Mine has the same problem...
But on friday they are going to put on some fog lights and I hope they will address the steering also.
Toyota Yaris 1.0VVT-i T2
apmatzen is offline   Reply With Quote
Old 02-23-2016, 04:37 PM   #9
lormagni
Drives: Toyota Yaris 1.33 SR
My car used to have the same problem when it was lowered on Eibach Pro Kits. I found out that it was due to the mechanic that didn't re-clock the bushings after installing the springs!
lormagni is offline   Reply With Quote
Old 02-23-2016, 05:19 PM   #10
justanotherdrunk
Drives: 2016 SE
Successfully fixed by the dealer
The Tech said the spec for steering wheel center is +/- 3 degrees
mine was -8 degrees to the left
it has now been optimized and is perfect
Old 02-23-2016, 06:25 PM   #11
ern-diz
ern-diz's Avatar
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 04:09 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 07:30 PM
