Old 03-08-2016, 12:33 AM   #1
tattoo007
Drives: 2005 Echo RS
2005 Echo RS Performance Upgrade Help Required!!
Hello everyone,
I am sorry to be such a newbie but I just purchased a 2005 Toyota Echo RS for my daughter and wanted to get some help to upgrade it. I read the forum on the exhaust and think I would like to go with the DC Sports new Manifold. I did see that I would need a Nitto mid-pipe but can't seem to find where to purchase one. If anyone has any ideas please send them to me!!
Also I would like to know for the Cold Air Intake for the Echo from you guys that have them to see which one would be better.
Any other information on performance parts to make it unique and better would be greatly appreciated!!
Thank you all in advance!!
tattoo007 is offline   Reply With Quote
Old 03-08-2016, 02:27 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
hmmm...i have full exhaust without the muffler..it doesnt seem to help much..intake start losing low mid power with high gain..this 1NZ engine, you really have to put effort in it...lol..its pain in the ass to make actually "fast" without turbo.. -_-
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 03-08-2016, 07:24 PM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Originally Posted by tattoo007 View Post
Hello everyone,
A new exhaust manifold is great place to start. If you have the money, you can also change the entire system all the way to the tailpipe, or just change out the muffler section. I use the original mid-pipe and are relatively happy with it.
After that a cold air intake would be a good upgrade as well. There isn't a huge performance difference between brands so don't have to go too crazy spending money on the most expensive one you can get.
One upgrade that i found made a big impact in daily driving though was to reduce the parasitic loss on the engine by replacing the pulleys with light-weight ones. (and flywheel if you have a manual transmission) Your engine will be a bit more rev-happy and it'll make it easier to merge in traffic. :-)
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Tags
cold air intake, echo rs, exhaust, midpipe, performance
2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . mpcv2000 Canada 73 05-20-2021 08:14 AM
Toyota Echo 2005 RS Performance Upgrade Help tattoo007 Canada 4 03-10-2016 10:30 AM
no more Yaris still keeping the 2005 Echo hatch Em_ General Yaris / Vitz Discussion 11 10-27-2015 01:27 AM
Just went from Echo RS to Yaris RS, Not really an upgrade.... Thor_e Performance Modifications 9 08-27-2013 02:16 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 04:23 PM
