Old 04-05-2016, 04:42 PM   #1
Pinchlite
Drives: 2007 yaris HB
Speaker depth front door 2007 HB 2 door
After doing research I came to the conclusion that these speakers would fit into the doors(2007 2 door hatchback)
The speakers I am going to purchase are 44mm mounting depthe 5.25 round speakers and want to be 100% sure they will not be too deep
P.S I am not asking if these are good because many will say they are junk but I dont want opinions on quality as these are cheap and better then the almost blown factory speakers.Thanks for the help.
http://www.bestbuy.ca/en-CA/product/...77750b70been02
Pinchlite is offline   Reply With Quote
Old 04-05-2016, 05:31 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
The depth will not be a problem.
brushforhire is offline   Reply With Quote
Old 04-05-2016, 05:36 PM   #3
Pinchlite
speakers
Thank you good sir.
Old 04-05-2016, 06:47 PM   #4
For your reference. Ruler is touching the glass of the rolled down window.
Old 04-05-2016, 06:48 PM   #5
Pinchlite
Plenty of clearance.Thanks.
Old 04-05-2016, 06:52 PM   #6
The link you provided is for 5.25". Stock fronts are 6.5" and the hole in the door is 6".
Old 04-05-2016, 06:56 PM   #7
Pinchlite
So what speaker measurment do I need for doors.6'' or 6 1/4''.And what are the rears?
This is a 2007 hatchback 2 door.Someone said on this same site that the doors are 5.25.
I will remove panel and check before buying.
Old 04-05-2016, 07:46 PM   #8
brushforhire
I put 6 3/4 components in mine. The mounting depth was 1 15/16th. I made a spacer to mount them with.
The front and rears are in the hatch are the same.
I would go with 6 1/2", you will also need mounting brackets.
I always recommend Crutchfield. You and enter your vehicle there, and it will tell you what will fit, and what you need to install them. They also give you mounting brackets for free.
Old 04-05-2016, 08:00 PM   #9
Pinchlite
Thanks for info.I am just going to remove speaker and bring it to the store to compare.I dont want to be messing around with brackets and all that stuff.I dont have the time for custom mounting/fenagling.Or I may just get a shop to install.Its not that I cant do as I used to do bodywork professionally so customizing isnt out of my abilities,but its just a time issue thing.
Old 04-05-2016, 08:30 PM   #10
brushforhire
You have to have a bracket to mount in the new speaker. The factory speaker's frame is its own mounting bracket. Once you drill out the rivets to remove it, the replacement speakers do not line up with the holes.
The brackets crutchfield supply bolt right up with no issues.
Old 04-05-2016, 08:38 PM   #11
Pinchlite
http://www.crutchfield.com/p_1208281...-Brackets.html
These here should do.I see what you mean how the speaker is attached to plate/bracket.
http://www.yarisworld.com/forums/showthread.php?t=40471
front door speaker pics severous01 DIY / Maintenance / Service 1 01-26-2011 12:04 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 12:08 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 03:26 AM
door speaker install gone wrong!!! punch In Car Entertainment + Electronics (audio / video / alarm) 17 06-28-2006 02:49 PM
