![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
6.2" LCD Double-DIN Receiver
What exactly is needed to install these.Currently the car(2007 HB) has faceplate for aftermarket receiver(pioneer detachable face)
I am quite experienced with electronics but not with car stereos.I dont want opinions on quality of unit or dont buy this but buy that.This is all I need and the price is right with shipping included(CAD) I just want to know if I will need another entire dash faceplate or just brackets.I dont need a harness as I will be soldering all the wires directly as I have the schematic/pdf/Wire color codes of the stock wiring. It looks like these brackets will be needed http://www.crutchfield.com/p_1209582...-Dash-Kit.html (Link to radio) http://www.visions.ca/catalogue/cate...560&sku=PD624B Thanks for any and all help. |
Just the brackets (trim kit) are required.
Alrighty then I will order these up but will see if I can get within canada first.Thanks for reply.
EDIT: found. http://www.crutchfield.ca/Toyota_Kit.../120958202.htm |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
I still highly recommend using the harness adapter instead of soldering directly into the car's harness.
Also, why get a no-name off-brand radio, when you can get a much better one for the same money? Pioneer AVH-X2700BS can be had brand new for the same amount all day long. |
168.00 CAD ship incl?
All the stock speak wiring is being removed.Soldering directly is no problem.I have the wiring diagram/color scheme for my model yaris.Its basic stuff. |
I seriously don't understand what you have against harnesses. Last year I had to replace the first aftermarket HU I put in years ago. Let me tell you, I'm sure glad it was not soldered in.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Exactly! In fact, you don't really need to solder anything. When i installed my head unit, i used an adaptor harness and tap-spliced and taped all the connections with electrical tape. Super easy and fast.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
I mean you can still solder the harness adapter to the tail of the plug that comes with the stereo, and then plug that into the car harness. But why make extra work for a worse result?
Wire harness:
http://www.ebay.com/itm/151703525069...%3AMEBIDX%3AIT Trim kit: http://www.ebay.com/itm/401104163191...%3AMEBIDX%3AIT Trim kit required some modification, had to reduce the horizontal thickness a bit. Both worked great on my `08 HB, S model. Used crimp type connectors.
- The Black Ship Yaris - Last edited by blktiger60; 04-30-2016 at 11:43 PM. |
#10 | |
http://www.ebay.com/itm/262350416231...%3AMEBIDX%3AIT Video and MP3 from USB or Mini SD, and Radio - no disc
- The Black Ship Yaris - |
I use canadian dollars.
Everything is wired up and working perfectly.Receiver,amp and subs.I always direct solder wires when possible.I dont like crimps either so I remove plastic and solder wire to connecters.+ I enjoy soldering. |
$67 from ebay, and it still works great 4 yrs later.
| Installing Double din Yaris 09 need HELP! | crimsonedge | DIY / Maintenance / Service | 0 | 07-08-2013 06:09 AM |
| Is Yaris HB 2007 Double Din or Single Din? | ediaz_pr | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 04-09-2010 07:41 PM |
