Old 04-21-2016, 02:29 PM   #91
Hanu91
Drives: yaris 2013
Hello!
I have manual yaris 2013 with 1.4 diesel engine. What parts do I need for the cruise to get it work?
Thanks
Hanu91 is offline   Reply With Quote
Old 04-21-2016, 07:38 PM   #92
Originally Posted by Hanu91 View Post
Hello!
Thanks
For the diesel, your only option is an aftermarket complete system.
Old 05-25-2016, 07:42 PM   #93
ScarabEpic22
Drives: 07 Toyota Yaris Base
Lots of good info here, thanks for having it as a resource CTScott! I've learned a lot reading through the threads about adding OEM cruise.
I'd like to purchase a wiring kit and indicator from you for my 07 LB AT, tried sending you a PM but looks like there's a minimum post requirement. Sent you a PM, if duplicate then I apologize in advance.
~Erik~
ScarabEpic22 is offline   Reply With Quote
Old 05-25-2016, 08:12 PM   #94
Go it and replied.
Old 05-30-2016, 03:44 PM   #95
Mikeyh
Drives: Yaris 2014
Cruise Control Installed!
Scott,
Thanks for the cruise control kit for my 2014 Yaris L. Just as you said, it was easy to install, really plug and play. Took about 20 mins. and the wiring you included for stalk and horn wire made connections simple.
If I can do it anyone can!
Anita (Mikey's wifey)
Mikeyh is offline   Reply With Quote
Old 06-09-2016, 04:20 PM   #96
signatureseries
Newbie
Drives: 2008 Yaris 3 door
Cruise Control Kit 08 Liftback (3door) Manual
I am looking for a Cruise Control Kit 08 for a Liftback (3door) Manual. I am open to either style (stock or switch). I am new to the forum so i don't believe it will let me send a PM. Do you have anything available?
Go it and replied.
The 34 page PDF file below is a complete DIY for installing OEM Cruise Control on a 2006 to 2011 Yaris.
This will only work for US/Canda/Puerto Rico Yaris, as Yaris from all other areas lack the built-in ECM programming for Cruise Control. Vehicles from other areas must use an aftermarket cruise control system.
Any procedure that requires 34 pages of documentation may seem intimidating, but this installation is really not difficult. I tried to add as much detail as possible to clarify the parts where people who have installed cruise control have had questions.
This guide is broken up in to seven sections encompassing the following:
Section 1: OEM Cruise Control Stalk Installation.
Section 2: Steering Column Connector D3 Pin Installation
Section 3: ECM Connector A21 Pin Installation
Section 4: Connecting the ECM Pin to the Steering Column Pin Through the Firewall
Section 5: Cruise Control Clutch Switch Installation
Section 6: Optional Cruise Control Indicator Module Installation
Section 7: Verifying Operation
http://tinyurl.com/CruiseDIY
signatureseries is offline   Reply With Quote
Old 06-17-2016, 12:59 PM   #97
maral01
Drives: 2007 Yaris Sedan
Hi, new here and just wanted to say thank you to CTScott for this awesome DIY! Installed it in my 09 liftback within an hour and it is working flawlessly. Pulled the parts from a 08 Yaris at the junk yard and, believe it or not, it had that same DIY done to it by the previous owner! Not bad at all, especially since it only cost me 6$!
maral01 is offline   Reply With Quote
Old 06-22-2016, 02:10 PM   #98
jra
Drives: 2015 yaris L
Would a 2015 five door L automatic U.S. Yaris only need the stalk and wiring to plug in to clock spring and horn? If so do you have parts for this?
jra is offline   Reply With Quote
Old 06-22-2016, 03:22 PM   #99
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The Series 3 cruise control installaion is very easy. See http://www.yarisworld.com/forums/showthread.php?t=37205 for details.
Old 06-22-2016, 07:41 PM   #100
Sudspt
Drives: Yaris
I have a question about my Yaris. I bought it in Las Vegas and I want to make sure that the ECU will tolerate the cruise control. It's a 2007 model. It says that it was manufactured in Japan, but it's a Toyota and that's where they're all manufactured, right? Just want to clarify that this method will work before I start rounding up the parts.
Sudspt is offline   Reply With Quote
Old 06-22-2016, 07:42 PM   #101
Yes - For your car, as with all American market Yaris, cruise control will work.
Old 06-23-2016, 01:14 AM   #102
Sudspt
Drives: Yaris
Thanks! I will follow your pdf instructions and let you know how it goes! Appreciate it!
Old 07-01-2016, 08:08 PM   #103
jra
cruise for 2015 U.S. Yaris L, french built
Scott
Thanks for the parts you sent, took about 15 min. to install, works like it was factory installed.
Old 07-24-2016, 07:09 PM   #104
Tomsyaris
Drives: 2010 yaris sedan
Hi Scott I Sent a pm . Thanks
Tomsyaris is offline   Reply With Quote
Old 07-25-2016, 07:07 PM   #105
David C
Drives: White '07 3dr LB
Hi Scott, if I was to use a switch and LED to do a basic setup, could you pinpoint the essential wires ? Would a lighted 4 way switch work as a CC stalk and on/off indicator or do the CC indicator module would still be needed to act as a smart relay ? I have a '07 3dr LB, Canada. PM me the details if possible.
Thanks
David C is offline   Reply With Quote
Old 07-28-2016, 09:40 PM   #106
bassmannate
Drives: 2008 Toyota Yaris
Just used your guide to install a stalk and wiring. Worked great! The only thing I ran into was that I read the part about the indicator as "Yes: You'll need the indicator kit" or "No: You won't need the indicator kit" so I was a little disappointed when no light came on in the cluster but so happy to have cruise control on this car! Might have to get the indicator kit sometime just to have it in there.
bassmannate is offline   Reply With Quote
Old 08-05-2016, 04:39 PM   #107
bassmannate
Well, we're on our first road trip with the cruise control and it hasn't been completely smooth. The on/off button doesn't seem to work reliably the first time after starting the car. After you get it to come on the first time, it works great.
Is this just a problem with the switch/stalk i got? Is the control just a resistor ladder and could i just install a momentary switch with a resistor across the leads?
Sent from my LG-H811 using Tapatalk
Old 08-05-2016, 10:34 PM   #108
Where did you get the stalk?
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
