Old 09-05-2016, 02:24 AM   #1
rabbito
rabbito's Avatar
whats your normal running temperature for your yaris?
mines running 86~90 all the time..no higher than 90 on my engine temp. gauge...i am running E85...
i live in thailand, temperature here is 40c/104f with heavy humidity
what about yours?
Cosmetic: Toyota red emblem
Old 09-05-2016, 05:07 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
I don't know, it doesn't have a coolant temperature gauge.
I presume it's alright because the low temp warning goes out and the red high temp warning doesn't come on.
mrpj is offline   Reply With Quote
Old 09-05-2016, 04:06 PM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
My scan gauge reads 184-186 degrees at operating temp.
Have Yaris will travel..
Old 09-06-2016, 12:17 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
what about yours?
That sounds normal, and pretty good for such high temps. Humidity actually helps the radiator work more efficiently.
Old 05-09-2017, 03:33 PM   #5
siriuss
Tweaker
siriuss's Avatar
Drives: 2009 Yaris Sedan
87*c or 188 F on the scangauge. Not enough for winter time at minus 25 C , it would need to be at 95C or 203F to be able to heat up the inside as it should be.
siriuss is offline   Reply With Quote
Old 05-09-2017, 04:11 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
No-idea degrees
On Instagram
On Wheelwell
Old 05-09-2017, 04:16 PM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
182-184 (83-84) always at driving speed.
Old 05-10-2017, 04:45 AM   #8
mrpj
Normal operating temperature, 90 degrees C using my scan tool
Old 04-16-2019, 02:54 AM   #9
rayfloyd170
Drives: Yaris 2016 1.3 Manual
same stats here on normal driving at 80-100kph i get 85-86 deg Celsius ( 184-186 deg F)
rayfloyd170 is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
Yaris vs Celica jesh462 New YARIS Purchase Forum 11 10-19-2012 12:49 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
