Old 12-26-2016, 07:50 PM   #37
CoryM
Drives: 2009 5-door, 5-speed
https://en.wikipedia.org/wiki/Dynami...ation_Absorber
Think of it as putting your finger on a small bell and ringing it. Much quieter right? I come by the info by knowing a bit about physics..... and being a mechanic :þ I would ASSume that by putting small dampeners there, it prevents the NVH from travelling to the body (which will amplify it) and potentially bother the driver. The other likely cause would be due to Toyota adding disc brakes to an existing twist-beam and finding squeal/groan complaints. Rather than making a new twist-beam they just bolt those dampeners on until the next redesign.
In practice removing that dampener will likely result in no noticeable change in NVH to the driver.
Old 12-27-2016, 01:11 PM   #38
davinoft
davinoft's Avatar
Drives: yaris
Go to fastenal.com and order part number 1111 6380 it's a M10 1.25 x 30 millimeter Bolt you can use these bolts to the factory bump stops with no problem I used on my 2014 SE model
Sent from my SM-G925P using Tapatalk
davinoft is offline   Reply With Quote
Old 12-27-2016, 09:29 PM   #39
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
In that case I'll just remove em. I don't know if there is a fitments difference between white and the TRD unit. Nvh doesn't bother me.
91mustang is offline   Reply With Quote
Old 01-04-2017, 08:01 AM   #40
lambo
Drives: 2014 Yaris
Thanks for the detailed info ... I was looking for a mod for my new (new to me) 2014 LE
lambo is offline   Reply With Quote
Old 01-04-2017, 01:35 PM   #41
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
The LE models do not have the dampers. Sway bar can be installed in normal fashion. The modification only applies to 2012-2014 SE models.
Old 01-04-2017, 02:29 PM   #42
91mustang
I installed my white line bar, I didn't have to remove any dampers on my SE. I honestly did not even see them or look for them during the install.
Old 01-04-2017, 03:24 PM   #43
NYC-SE
NYC-SE's Avatar
Then they weren't there. If they were it would be obvious. Did you buy the car new?
Old 01-05-2017, 01:17 AM   #44
91mustang
I'll take another look, I think it is because the white line installs differently.
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
FS: TRD Rear Sway Bar NY/CT/NJ enviri Items for Sale by private party 8 06-13-2013 10:46 PM
Any interest in a used TRD rear sway bar? ricktoyota73 Items for Sale by private party 10 09-06-2012 10:08 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
TRD rear sway bar cali yaris Items for Sale by private party 19 05-23-2009 05:23 PM
