Old 02-27-2017, 04:12 PM   #1
Pinchlite
Drives: 2007 yaris HB
Strut problem?
I have 2 new kyb struts in front of me ready to go on.
I got tire off and see the rubber bellow is torn.
I talked to KYN directly and they said there is a piece that needs to be cut out and reused or put new one in.
It seperates metal on metal contact.
I was going to get these but he said it may not work.
https://www.autopartsway.ca/partdeta...n-strut-bumper
Does anyone here changed strut on 2007 yaris Hb 2 DR.
I am confused as to what this plastic piece is that he says needs to be cut and reused or buy another as its part of the strut assembly.
From what he described its a hard plastic piece connected to the bellow.
I do not believe he is talking about the plastic piece that goes between shock and round metal cups on top/bottom of strut.
Here are the struts that I have
https://www.autopartsway.ca/partdeta...strut-assembly
UPDATE:
I see what he means by the bellow
http://i.imgur.com/oIO13OE.jpg
Cant seem to find this exact bellow though as its different then the one I linked above
Old 02-27-2017, 04:21 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
It sounds like they're talking about the bump stop. I had to cut mine 1.4 inches when installing my Tein springs to make room for the additional strut travel. Something like this:
https://www.walmart.com/ip/42934657?...&wl13=&veh=sem
On Instagram
On Wheelwell
Old 02-27-2017, 04:38 PM   #3
Pinchlite
bellow
No he was not talking about the bump stop or plastic spacer that seats between spring and and strut cup.
I realize i need to cit 1.5 off the bump stops as my springs are 1.5 drop.
I took a look at my strut closer and need a special boot/bellow that has flange ontop that sits ontop of spring.
Looks like I need to track this down.
http://i.imgur.com/AMLdd2z.jpg
Looks like I found a work around.
I can use the stock boot and cut the ripped part out.Then use these bellows underneath.
https://www.autopartsway.ca/partdeta.../pagenum1/tabs
http://i.imgur.com/oroZaGk.png
http://i.imgur.com/gXWAzKN.png
Old 02-27-2017, 04:52 PM   #4
ern-diz
ern-diz's Avatar
Ah, gotcha.
On Instagram
On Wheelwell
Old 02-27-2017, 04:56 PM   #5
Pinchlite
Bellow.
Ah, gotcha.
Ebay looks like the only option in Canada here....though the KYB ones may do the job.
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Rear hatch strut problem MiSFiTx87 DIY / Maintenance / Service 10 08-29-2014 11:15 AM
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
