Old 06-10-2017, 12:00 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
How to access alternator bolt to remove alternator or replace belt
Hi all, I use a 1/4 drive 14mm socket and a 1/4 to 3/8 adapter to a big Armstrong thin head locking flex ratchet (11-994). Here's some pics.
Toolaholic is offline   Reply With Quote
Old 06-10-2017, 12:01 PM   #2
Toolaholic
[IMG][/IMG]
Old 06-10-2017, 12:02 PM   #3
Toolaholic
[IMG][/IMG]
Old 06-10-2017, 12:03 PM   #4
Toolaholic
[IMG][/IMG]
Old 06-10-2017, 12:05 PM   #5
Toolaholic
[IMG][/IMG]
Old 06-10-2017, 12:09 PM   #6
Toolaholic
The photos show I didn't have to remove a/c line fasteners.
Old 06-10-2017, 12:10 PM   #7
Toolaholic
Another way is a 3/8 flex ratchet and a 3/8 socket but when you break alternator bolt loose don't hit the a/c hose.
Old 06-10-2017, 12:10 PM   #8
Toolaholic
[IMG][/IMG]
Old 06-10-2017, 04:03 PM   #9
kwk442
Drives: 2010 Yaris
I just used a small wrench...
kwk442 is offline   Reply With Quote
Old 06-10-2017, 05:12 PM   #10
Toolaholic
If you broke that 14mm bolt loose with a small wrench the first time you should enter arm wrestling contests. The bolt is on really really tight from the factory. After I broke loose for the 1st time it is easy to loosen as I torque it to the factory spec of 40lbft( for some reason it is on much tighter than 40lbft from factory). Now that it's torqued properly I could probably break it free with my long handle matco 1/4!drive ratchet.
Old 06-11-2017, 06:33 PM   #11
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
The u take it out ??
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 06-11-2017, 07:02 PM   #12
Toolaholic
I have had it out for testing. The lower bolt is long.
Old 06-11-2017, 07:10 PM   #13
Yaris874
Yaris874's Avatar
Yea it is I had to take out the size 10mm slide the bracket for the ac line to the side and was out my alternator light is Ben on for almost a year but the alternator still work
Old 06-11-2017, 08:41 PM   #14
Toolaholic
with my way 10mm ac bolts stay put. And a gearwrench torque wrench fits. The 3:8 to 1/4 adapter with 1/4 drive 14mm socket clear the alternator but still leaves room for ratchet to clear a/c lines. Bolt is so long I might have removed the 10mm bolts. Definitely do not have to remove 10mm bolts to move alternator to remove and tension belt.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 08:32 AM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-14-2014 12:17 AM
