Old 06-21-2017, 11:45 PM   #1
Hard_Yaris
Drives: 07 Yaris
positive to negative fuse pop
Please help me, for I have commited a bone head move.
I placed the new battery in and started hooking up terminals
upon placing the second terminal on some sparks which i though were normal, but then i heard a POP right next to me... can some one help me with what fuse would of likely popped?
NO turnsignals, fan, radio, hazards, brake lights, and now there is an ABS light on the dash. It does Start a lot stronger now.
This happened on a 2005 toyota echo and i have a 2007 toyota yaris that maybe i could borrow some fuses from.
i really want to go joy riding tonight, all help is appreciated.
Thanks
Hard_Yaris is offline   Reply With Quote
Old 06-21-2017, 11:56 PM   #2
Hard_Yaris
Drives: 07 Yaris
upon closer inspection, i did blow the main fuse that sits onto to the positive terminal... so does anyone know if i should be concerned about anything else after this bone head move?
Oh, and of course the 2007 Yaris fuse is different
Old 06-22-2017, 12:21 AM   #3
Hard_Yaris
Drives: 07 Yaris
I found this from CTScott
The Yaris does not have any significant reverse voltage protection, so you can do some serious damage connecting a battery backwards.
To start with, disconnect the two ECM (engine computer) connectors and see if DOME fuse still blows. If it does not, then you may have damaged the ECM (which is the most sensitive device to reverse voltage).
where are the two ECM connectors located?
Old 06-22-2017, 12:53 AM   #4
Hard_Yaris
Drives: 07 Yaris
"To protect from reverse polarity you need a diode (which the newer cars may have)."
Can anyone reassure me that my 2005 echo has a diode to protect against stupidity?
help re wiring fuse box please kommodore DIY / Maintenance / Service 1 04-01-2014 02:11 PM
power outlet/cigarette lighter fuse location Idahotom General Yaris / Vitz Discussion 1 01-08-2014 05:45 PM
Fuse Fix bronsin General Yaris / Vitz Discussion 4 12-18-2011 02:05 AM
LED positive negative question ASAP Sway84 Cosmetic Modifications (Exterior/Interior) 2 06-21-2007 08:39 AM
Yaris Positive or Negative grounding system? marcus General Yaris / Vitz Discussion 2 04-20-2007 10:25 PM
