![]() Drives: 2010 Toyota Yaris Join Date: Jun 2017
Mystery Device in my Yaris?
Hello Everyone,
I just bought a 2010 Yaris from a used car dealer. The previous owner had installed some type of electronic device and I haven't been able to figure out what it is yet. I'm wondering if anyone here might recognize this device by my photo and can tell me what it is? It has a red button on the face, but when I push it, nothing seems to happen. It does have 2 wires tying it into the circuit board and several wires going right under the dash and one wire going back and disappearing under the door jam cover. Thanks! |
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
Try pushing the button while the car is running and turn the key off. It might be a device like the cop cars have that will keep the engine running without the ignition being on.
-Karl the Uber/Lyft Driver |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Was the guy named Bruce Wayne by any chance ?
replies
Thanks for the idea!
DAK - I tried this as you suggested.......and when I did.......the engine stopped like normal (when the key was turned off with the button depressed). I did unscrew the device from the dash so I could see the back of it. I thought there might be some brand name or other such clue as to what it was.......no luck with this either. DC - No.....the name on the title was not the one you mentioned |
I also thought that the wires that were tapped into might be a clue. You can see this in the second photo.
That looks very similar to the device I have in the same place in my car. Mine is part of my K.A.R.R. security system. Was pre-installed by Toyota and offered as an option. Supposedly a very programmable security system, but I've never used it beyond regular alarm functions.
Its hard to tell what is spliced into what color wire from those pictures but it looks like they are leading up to the brake lights. As odd as this question sounds for this car, did the previous owner have a hitch installed on the back? This is possibly a switch for the additional brake lights when hooked up with a trailer. Just a guess based on the area the wires are running to. It's not an immobilizer mandated by the courts because it's not RFID and I don't see the breathalyzer unit anywhere that is usually center mounted on the dash.
Hmm... Try pressing the button first, waiting a moment, and then turning the key off. I'm really curious what it's for now lol
Took a pic of mine for comparison...
If that's a dealership item, that is the single most ugliest, backyard'ish, "hey, I have a friend that can install it" thing I've ever seen come out of a dealership. Let's just bolt the damn thing to the dashboard...
I have one in my car as well. Dealer said it was part of the security system. He offered to remove it if I didn't want it, but I never made an appointment to get that done. I actually forgot about it until I read this thread. Guess I'll just leave it there.
If I remember correctly, it's what's used to program the system. Can turn it off, set it to valet mode and do a number of other things that I never looked into once.
Yup, most likely an aftermarket theft system. If you are really curious, try cutting a key somewhere, and using that cut key to start the car without any of the primary keys near the car. If it doesn't start, then it's an immobilizer of some sort.
Thanks for all the input!
I just had another idea......I was wondering if it might be an unlock button for the hatchback after I just ran an errand and needed to get into the hatchback and had to shut the car off in order to take the key back there to unlock the hatchback. This would have been a great thing to add.....so you could easily open up the locked hatchback without having to shut the car off or have another key.......No Dice! This is not what the button does either. The key that I used as my primary key is a cut key (not a factory key). No starting issues........I don't think it is an immobilizer. If it was a security system.......you would think it would do something when you pushed the button wouldn't you? Chirp or make a sound....or maybe there would be a light? There is no sound or lights that I can see. |
Usually aftermarket alarm systems have a push button wired to the main unit to use for setup and valet mode, etc. usually they'll put it under the driver kick panel, out of the way and view.
Pretty much what I've been saying lol.
For sure, no worries at all. I just got a laugh out of it because I said it, Kimona said the same, Kaotic (who works for Toyota) thought the same, then you confirmed, but it seems like the mystery lives on regardless lol.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
