Old 07-11-2017, 09:19 PM   #37
I don't know why the @$&# this thread got woken up after 9 years.
Old 07-11-2017, 10:17 PM   #38
dogsridewith
Drives: 2007 2-door hatchback
so what changed about hypermiling or sceh's 2004 Yaris in those 9 years?
Old 08-25-2017, 11:56 PM   #39
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Why not just turn on AC as you're going down steep hills while in gear? You're gonna need to keep tapping the brakes anyways to slow down, minus well use the drag created by the AC to slow you down.
07liftback is offline   Reply With Quote
Old 09-07-2019, 10:25 PM   #40
carstudiopk
Drives: Toyota Belta 1.3, 2008, 3SZFE
Engine braking itself is enough.
Sent from my vivo 1727 using Tapatalk
carstudiopk is offline   Reply With Quote
Old 02-16-2020, 07:11 PM   #41
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I actually see very little difference in fuel consumption while using the AC. Really, spending a few US pennies to be comfortable, especially if you are in a hot climate, is not that big of an issue. Turn the AC on and pamper yourself. You deserve it for purchasing a Yaris in the first place.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 09-24-2022, 12:34 AM   #42
dindoul
Drives: toyota Yaris
Using the A/C use 1 litre more per 100 kilometers.
Open the windows when driving under 80kph
dindoul is offline   Reply With Quote
Old 10-13-2022, 12:45 PM   #43
Neinris
Drives: 08 Yaris 3 Door Hatchback
I simply cannot understand not using the AC and being uncomfortable to save a minuscule amount of money on gas, ESPECIALLY with current prices at about $1.60 a gallon.
I drive about 350 miles a week and with current prices, it costs me only about $15 a week fueling the Yaris. Turning the AC off (although not using it right now in December of course), would save maybe $.50 a week. Um, what's the point especially when discomfort is the main result? Do we really need that extra piece of gum?
I wished that gas still only cost $1.60 a gallon like back in 2008!!!
Neinris is offline   Reply With Quote
Old 10-20-2022, 06:35 PM   #44
sh0rtlife
even at over 5$ a gal im happy i retrofitted the AC option and it gets used price gouged fuel be damnd
Old 10-31-2022, 10:51 AM   #45
ltwargssf
Drives: yaris
I have a scan gauge and idling/slow speeds with the ac on you will get a noticeable mpg drop. Once you are going and cruising its not much at all.
ltwargssf is offline   Reply With Quote
Old 11-01-2022, 05:24 PM   #46
sh0rtlife
i can verify that with "real world" use....been delivering a a IC for a big box co, and can tell you without a doubt that idling with the AC on will KILL your mpg, but wide open HWY running it may ding you 1 point at best....dead of summer full AC running i found it wasnt the travel hurting it was the idling IE stop grab package sprint for door sprint back to car GO GO GO, but when your talking about 40-50 stops of sitting idling for 30sec to a min per it adds up fast
someones going to spout shut off the car, yeah our AC systems suck to get "up to speed" but work really well once they are ahead of the heat curve/humidity..and the amount of time to re-cool and remove the humidity we had this summer..your at your next stop swetting bullets and the car has just started to cool again and your shutting it down..by the 3rd stop youve got enough engine heat soak into the cooler that you leave it running for the next 3 stops to "catch up" or you suffer the heat and shut it down entirely as its pumping more humidity into the car trying to play catchup
all said if im delivering with the AC running full and idling at stops i noted a drop from my 27 to 25, while my wife who isnt as fast noted a drop down to around 27..Ie she would spend more time idleing than i would
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 05:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 02:50 PM
A/C & Aftermarket intake KSIbucky DIY / Maintenance / Service 2 03-26-2007 10:08 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 09:26 AM
