Old 08-29-2017, 01:01 PM   #1
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
Retrofit a OEM Garage door opener from Toyota
Anyone done this; retrofit another Toyota/Lexus built in garage door opener into their Yaris?
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 09-02-2017, 10:12 AM   #2
weevil
Drives: 2013 Yaris YRS
I retrofitted our generic garage door opener into my Yaris. $20 on a momentary switch and two tiny dabs of solder. Very easy, looks and works great.
weevil is offline   Reply With Quote
Old 09-06-2017, 10:00 AM   #3
GibbsYaris07
If you could, please share pics. What about Homelink?
The Gibbs Garage
Old 09-06-2017, 11:21 PM   #4
weevil
Same principal as this:
https://www.youtube.com/watch?v=ieyPtIhuezQ
But my garage door opener had a hole I could put the wires through so no need for an extra box. I also did not use a multimeter. I just experimented touching the wires on the connectors and pressing the button until I found the ones that worked (very easy).
And instead of drilling holes I just bought one of the below on eBay.
http://www.aironboard.com.au/store/p...momentary.html
Even connected the switch’s light to the car power so it lights up when keys are in the ignition.
Don’t know anything about homelink but it should work with any door opener.
Works perfectly and looks 100% like it’s a standard part of the car.
Old 09-08-2017, 10:23 PM   #5
govtec
Drives: 2007 Toyota Yaris Hatchback
I did it over the weekend when I installed the Scion stereo conversion. I installed the auto dim mirror along with garage opener. I got the mirror off of eBay. You only need to connect 3 wires (acc, 12v constant, ground). I ran the wires through the A pillar. Have a look...
govtec is offline   Reply With Quote
Old 09-08-2017, 11:59 PM   #6
GibbsYaris07
nice job. This is what I was referring to initially.
The Gibbs Garage
Old 09-09-2017, 12:56 AM   #7
govtec
Only cost $75 bucks from eBay and the mirror bracket is plug and play. The mirror is made by Gentex
Old 09-11-2017, 09:06 AM   #8
GibbsYaris07
What did you use for ACC and constant power? This is a good effective mod btw.
The Gibbs Garage
Old 09-11-2017, 11:33 AM   #9
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
What is the part number on that mirror?
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 09-11-2017, 09:42 PM   #10
govtec
I used the wiring instructions from Toyota that I found on another post. Basically run the wires down the A pillar and tap the side mirror control plug. See attached instructions. I connected both power wires in the mirror to ACC. Didn't have a need for 12V constant as I don't plan on using the garage door opener when the car is not on.
Old 11-19-2021, 07:27 AM   #11
Ferted
Drives: Tayota
Is it possible to install buttons to open the gate in the car?
Ferted is offline   Reply With Quote
The Toyota 1NZ Enthusiast's Garage on Facebook fnkngrv Off-topic / Other Cars / Everything else Discussions 3 04-07-2014 02:55 PM
FS: OEM Toyota wheel locks (for alloy wheels) Cosworth Items for Sale by private party 0 08-07-2013 03:53 PM
FS: Toyota OEM Stubby Antenna - Part # 86309-02090 white_rice Items for Sale by private party 19 03-18-2012 09:10 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 04:16 AM
