Old 09-30-2017, 10:47 AM   #19
tmontague
tmontague's Avatar
2nd day - Woooot big update!
So I headed out to TMP for the second time yesterday afternoon with my wife and a new driving technique that I wanted to try out.
I do have a couple poor quality videos and a bunch of pics my wife took, none are amazing but I'll post them up later tonight.
I used Harry's lap timer and finally started timing my laps. I don't have anything to compare my past lap times as I never timed any laps the first time at the track. My fastest lap was a 1:32:59 which is actually not too bad considering the set up of the car. To put it in perspective a 1:25 is considered a very fast lap for a fwd set up. Subjectively I felt that I was much much faster this time than last, probably about 8 seconds per lap faster.
The one new skill I learned and put to the test was utilising the throttle to control the car around corners instead of the brake. This lead me to be able to trail brake or quickly pull off the throttle to briefly unweight the rear. This cause over steer and kicked the rear around and better placed the car into the corner. I would then give it some throttle to control the over steer. I did this before but not using the throttle to stop the over steer so this lead me to having to do it at a much lower speed.
There is also a wide long turn (actually 2 90 degree corners close together which is treated as one) right before the long straight away. Previous to this I would trail brake in the corner and I would be severely limited in speed by the grip in the rear. Because my car is set up to be tail happy my speed was relatively slow as my rear end was so light and floaty. I forced myself to actually only touch the throttle around this corner and I found myself able to corner about 20km/h faster as the throttle was used the keep weight on the rear wheel so the car hooked up better around the whole corner. This one change made a world of a difference.
I also started braking later and harder into corners, it is hard to get comfortable with but I'm realizing how much more I can squeeze out of the brakes.
I started with a cold tire pressure of 32/29 fr/r and I think I finally found the sweet spot for these tires. Once warmed up they stopped sliding and pushing everywhere like last time and they appeared to wear much better with no melted rubber. They actually looked clean and smooth after each lap. I was pretty impressed with the amount of grip I was able to hook up. ambient temps were 18 degrees C so much cooler than last time.
I ended up doing about 63 laps (over 180km) and went through 3/4 of a tank of gas! I stayed on the track longer each session this time for approx 30 mins as it was too much fun once the rubber heated up.
By the end of the night on my last session I was playing tag with a twin turbo V6 Mercedes sedan (the driver normally tracks an RX-7. He would gap me slightly on the straights but in the corners I was faster. We ended up catching up with a Mustang and 2 boosted BMW coupes and I managed to stay with them for a bunch of laps. I actually was held up by them in the corners.
The driver of the Mercedes actually came over to speak with me and made a comment about me having a beast under the hood because of how fast the car was, he said he couldn't believe a Yaris was running with the group of cars and actually faster in the corners.
Listening to people who have years of racing experience has been a huge help. Its not always easy to do many of those things as your brain sends off warning signals but a car can be pushed much harder than your brain thinks. I finally got to experience how much control a driver has over the rotation of the car simply by using the pedals. This blew me away at how effective it was for allowing your car to go through corners fast and under control.
I got to experience how being smooth on the pedals makes for faster lapping. Many of the cars I was following weren't very smooth and I could see how uncontrolled the car was and how they were relying on the electronics of the car to help them from spinning out.
An LSD is a definite must for next season as I feel that my biggest loss was not being able give it much throttle during exiting a corner. I would try but I could only give light throttle or else the tire would spin. I also now realise how important coil overs will be for this car, my current set up isn't enough now that I am cornering faster. I'm thinking something with the same spring rates frotn and rear and adjustable dampers so they aren't too harsh for DDing
i found that this smoother driving lead to the tires not heating up/potentially over heating which lead to much smoother tire wear. I feel before I was very rough on the tires due to my poor driving skill.
i'll post pics up later tonight, I have a hilarious video of my wife's commentary during her very first hot lap after the tires warmed up. She found it easier to enjoy once she had been out for a few sessions but her first hot lap hat her cursing every second, it was hilarious.
FWIW Harry's lap timer is an excellent app and well worth the $10 IMO
Old 10-01-2017, 01:50 PM   #20
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Awesome dude. You are right about controling the car with the pedals, once you know how it reacts to certain inputs you can manipulate the car into controled slides.
Regarding the coilovers, they do help a lot in tuning but require regular inspection and corner balancing can be annoying. And at $1000 I would rather have the LSD
ArmstrongRacing is offline   Reply With Quote
Old 10-01-2017, 09:56 PM   #21
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
The other guys weren't smooth because they were trying their hardest to get away from a Yaris.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 10-02-2017, 03:55 PM   #22
tmontague
tmontague's Avatar
Some pics/vids
[IMG]<img src="https://scontent-yyz1-1.xx.fbcdn.net/v/t1.0-9/22046917_10155841025572743_3408168392878960618_n.j pg?oh=f5c5509c25328b73471523b1d58e7099&amp;oe=5A45 04D2" alt="Image may contain: 1 person, sitting"/>[/IMG]
Old 10-02-2017, 04:04 PM   #23
tmontague
tmontague's Avatar
Video upload
Here is the video of my wife on her first hot lap, this is after about 4 warm up laps to get the tires up to temps. She went out with me for about 4 sessions after this and by the end was much more comfortable and actually really enjoyed herself.
I figured most of you would find it amusing when a lay person experiences their first hot lap.
https://youtu.be/yA5Rb-s-LhM
Old 10-02-2017, 04:11 PM   #24
tmontague
tmontague's Avatar
Originally Posted by ArmstrongRacing View Post
Awesome dude. You are right about controlingredients the car with the pedals, once you know how it reacts to certain inputs you can manipulate the car into controled slides.
an LSD is without a doubt the next thing I will be purchasing for the car, it sounds like ti's the best bang for my buck at this point.
I'll likely just go with Megan coil overs down the road, I can't justify over a grand USD for a car that isn't my full out track rat. I don't really need all the bells and whistles that a >$1k set of coil overs gets you. I just need a much stiffer spring set up and compression adjustment so I can make them very stiff for the track and moderate for DDing.
I was chatting with Barber who tracked on the Megans as well as DD them and he was pretty content with them. As of now I'm on 4k/3k f/r set up with oem dampening in the front and Tokiko HP in the rear. I love how it makes the car tail happy and want to keep with the stiffer front than rear set up.
Old 10-02-2017, 05:12 PM   #25
Hilarious! If I watched that with my eyes closed I'd swear it was porn. Much like a TV commercial we have which promotes described video for the visually impaired.
Old 10-02-2017, 07:24 PM   #26
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Ha! That was great; thanks for sharing.
On Instagram
On Wheelwell
Old 10-03-2017, 11:07 AM   #27
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Video shows that you don't need a Ferrari to scare the womens :D
DiCaprio is offline   Reply With Quote
Old 10-03-2017, 11:01 PM   #28
ArmstrongRacing
Data doesn't lie
Talking
OR the men......
Wait until you are comfortable with the car to slide the rear around in the turns, that's when it gets you heart pumping for real
Old 03-05-2018, 06:31 PM   #29
bri62
Drives: WHITE YARIS
tmontague, are you going to TMP in spring 2018? I would love to go but it would have to be a week day.
bri62 is offline   Reply With Quote
Old 03-05-2018, 07:01 PM   #30
tmontague
tmontague's Avatar
Yup, I go on Fridays open track day from 4pm to sundown, $70+tax a week ahead purchased online or $100 cash all in day of.
My plan is to get their every second Friday starting mid to Kate April. Fridays are the days I went last year and its a much quieter session than the weekend ones and much cheaper. IMO 4 hours is more than enough I don't need a full day.
Shoot me a PM if you're interested in joining in. No one I know is interested so I always head out solo. Its nice to have someone to shoot the shit with when in the paddocks resting and to chase around the track
Old 03-05-2018, 10:18 PM   #31
Ugh, i went sideways at about 100kph in my yaris at the first of those 90* turns, lol
Good times.
Old 03-06-2018, 10:45 AM   #32
tmontague
tmontague's Avatar
^yup cold tires on that first corner can give you a surprise!
Old 03-06-2018, 01:46 PM   #33
That dip mid corner and the big rsb was enough to send me sideways!
Old 03-15-2018, 09:39 AM   #34
bri62
Drives: WHITE YARIS
What brake pads are you all using for track days and do you take them off when DD?
Carbotech XP8?
Old 03-15-2018, 09:58 AM   #35
tmontague
tmontague's Avatar
Hawk hps. Keep them on all the time, they don't squeak and handle track temps good and are priced well.
Your abs will kick in a lot when you first swap to them as they grab more
Old 03-15-2018, 04:02 PM   #36
ern-diz
ern-diz's Avatar
Nice.
What's ABS again?
On Instagram
On Wheelwell
$105 Track day @ Willow Springs- Big Willow Dec 21st judd Tracking, Racing, Auto-X Forum 0 12-15-2013 12:50 AM
August 18th Sunday-Touge.ca Mosport DDT track event 12:30-5pm #15 of 20+ Events! Touge.ca Canada 1 08-17-2013 07:00 AM
April 14th Shannonville Full Track lapping event 3:15-7:15pm, 1st event of 2012! Touge.ca Canada 3 04-12-2012 10:15 PM
July 3rd Mosport DDT Track lapping event (Sunday) -9th event of 2011, 1pm-5pm Touge.ca Canada 0 06-23-2011 03:53 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 08:07 AM
