![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
Part Identification Please?
I got into the inner fender on the drivers side of my 07 Hatch and found a part I don't know what it is. It's a resistor of some sort, and the white ceramic is all busted up. Can someone tell me what it is for? Thanks!
Crap.. was going to post a pic, but I will have to wait until I get to a PC. |
Here it is.... seems kind of strange to put it in the inner fender.
that's a weirdo thing. i wonder what that is?
it's the resistor for the controlling the 2 speeds on the cooling fan. You need this if you have A/C.
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Its your cooling fan resistor. I ended up with a spare one from a front end i salvaged off another Yaris. I've seen them on eBay for less than £15.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
As mentioned.
It is a large wattage resistor in the fan wiring. Connected in series with the fan motor for the lower speed. A relay should short across it when the fan is needed at full speed. |
So yesterday I went to the wrecking yard. Couldn't find one of these unicorns.... I mean ballast resistors. So I went over to NAPA and asked if I could go through the book and find a 1.3 ohm ballast resistor. Found that Mopar used a double ballast on some of their vehicles with a 1.28 ohms on one side, and 5.X on the other (NAPA Echlin ICR 24 is the part). So, I bought one of them for 8 dollars and put it in. I measured it with a meter in the store, and measured 1.3 ohms on it anyway.... so I'm happy, lol. Thanks for the help my friends....
BTW, the dealer wanted 138 dollars for this thing. If you go this route, just be sure to measure and use the correct side. ![]() ![]()
neat!
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 12:01 AM |
| DIY - Carbon fiber wrapping | Brian | Wash, Wax, Detailing, Exterior Repairs | 15 | 07-10-2016 12:34 PM |
| Evap canister part number for 2007 yaris sedan | baseballfan416 | DIY / Maintenance / Service | 4 | 04-25-2015 11:16 PM |
| Part identification | Flammable | DIY / Maintenance / Service | 2 | 02-23-2015 09:54 PM |
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 01:33 PM |
