Old 04-10-2007, 12:47 AM   #37
spkrman
Drives: 1
Originally Posted by jamal1984 View Post
can this thing read my tires Pressure?
no.
Old 04-11-2007, 06:55 AM   #38
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
The best I have got so far for a whole tank is 44.6 mpg hope to hit 45mpg sometime
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 04-11-2007, 03:06 PM   #39
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
Position of Scangauge
Just wanted to show how I mounted mine, the picture is exactly the veiw I have while driving, the gauge doesnt block my veiw of the cluster.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 04-11-2007, 04:22 PM   #40
MudBug
Drives: 07 Yaris
are you guys using the velcro?
That stuff won't fly here in AZ, the sticky stuff just melts and makes a mess.
MudBug is offline   Reply With Quote
Old 04-11-2007, 04:36 PM   #41
BailOut
Steals terrorist's lunch
BailOut's Avatar
I used to have the same problem in Texas, but then I tinted my windows and started using a windshield sun shade, and kept my windows very slightly cracked. I never had a problem like that again, and got a much cooler interior for myself along with it.
Once you do the tint, shade and crack thing you'll wonder how you ever got by without it.
- Brian
Share the Road
Old 04-27-2007, 07:52 PM   #42
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
My ScanGauge came today, and I'm trying to figure out a clean OEM look. I plan on getting a Nakamichi CD400 single din unit with a Metra dash kit. I'm curious to see if anyone was able to put the scan gauge in there in the pocket.
BTW, I finally got 41mpg today, before I got my scan gauge. I hope that it will help me get to my goal of 45!
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 04-27-2007, 08:28 PM   #43
365Motorwerks
Drives: Small and Black
-->From page 2, echo_hrs has the look nailed!
Originally Posted by echo_hrs View Post
I made a custom shroud for mine, and mounted it in the 1/2 din under my stereo...Cable run behind the dash to the OBDII port...
Cheers
365Motorwerks is offline   Reply With Quote
Old 04-27-2007, 08:37 PM   #44
nebulight
Novice Hypermiler
Yea, I saw that one, but I was curious about the pocket. I really don't feel like making one like that because I need to remove it from time to time to use it to check codes on my friend's cars.
I would think that the lower pocket would be nice if it could fit right in, kinda like my wideband sensor on my old car, it would look nice and out of the way when I have it in the car, but can still take it out easy if needed:
Old 04-27-2007, 08:40 PM   #45
nebulight
Novice Hypermiler
Taken from eBay, I'm curious if anyone has done it, or has measurements so I can take a ruler to the scan gauge:
Old 04-27-2007, 09:08 PM   #46
365Motorwerks
I have the same single din adapter and the ScangaugeII doen't go right in you would have to cut the lower pocket a bit to fit...
Old 04-27-2007, 09:30 PM   #47
nebulight
Novice Hypermiler
Any pics?
Old 04-27-2007, 10:29 PM   #48
MudBug
Drives: 07 Yaris
OK I tried it and after 2 weeks I looked at it today and found the velcro is sliding down the steering column as the glue melts in the heat.
I'll have to find another way to mount it.
Old 04-30-2007, 12:03 PM   #49
365Motorwerks
Any pics?
Unless somebody beats me to it I'll take one for you later..
Old 04-30-2007, 04:06 PM   #50
nebulight
Novice Hypermiler
Thanks man! That'll be nice.
Old 05-02-2007, 12:49 AM   #51
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
MPG
Has anyone done any realtime milage checks at different speeds...say 50-55-60-65-70-75? I realize everycar would be different, but figures like this on a calm day on a straight level road would give an indication where milage drops off....for some of us that can't quite shell out the money for one right now.
Thanks in advance if anyone would take on the challenge!
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 05-02-2007, 01:33 AM   #52
BailOut
BailOut's Avatar
Depending on temperature, road conditions, etc. our most efficient speed is in 5th gear/OD somewhere between 35 and 45 MPH.
For highway speeds 51-55 MPH is the most efficient, with a large drop-off between 55 and 65 and a punishing drop-off above 65.
- Brian
Share the Road
Old 05-02-2007, 07:19 PM   #53
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Bailout,I must disagree,I can still pull 41-43mpg at 70-75mph,and 52.5mpg at 53-58mph,cruising when possible,from 58-53mph,not letting speed drop below 53.I do have an opened intake and exhaust,so this does help,but either way,there is only a 20% diffrencen from say 55-75mph,not such a huge drop off,actuallly pretty proportional, relative to your speed.
eco is offline   Reply With Quote
Old 05-02-2007, 08:10 PM   #54
BailOut
BailOut's Avatar
eco,
Most folks would call a 20% difference in fuel efficiency a huge drop-off.
- Brian
Share the Road
