Old 04-29-2007, 01:35 PM   #19
Toyota Technician
Drives: 2007 Red Yaris LB MT
the yaris has a timing chain, no currently produced toyota engine has a belt except for the 2uz-fe 4.7.
Toyota Technician is offline   Reply With Quote
Old 05-01-2007, 11:27 AM   #20
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well we i know its a chain.. its actually the noise when accelerating is what were trying to figure out...could be the chain making the noise..
Old 05-01-2007, 11:32 AM   #21
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
You should replace the washer fluid with high performance red super temp, it's great at keeping the washer fluid cool when the 105.2hp is cranking away. That'll fix 'er.
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 05-01-2007, 11:52 AM   #22
marcus
toyota
marcus's Avatar
washer fluid??? you mean the rad coolant/engine coolant>>
Old 05-01-2007, 12:18 PM   #23
Nimble
Nope, I meant the washer fluid. It's a highly underrated, intricate part of the engine's function.
Old 05-01-2007, 07:11 PM   #24
marcus
toyota
marcus's Avatar
ey nible.. ur getting the coolant mixed up with the washer fluid.. totally different fluid.. one for the engine (coolant) and one for washing your windshields. (washer fluid)..
Old 05-01-2007, 07:14 PM   #25
Nimble
Lol, you are ruining it! It was a j-o-k-e! lol :)
Old 05-01-2007, 07:30 PM   #26
marcus
toyota
marcus's Avatar
oh i see it may not work here you might wanna do that on the honda fit forums...lolz
Old 05-01-2007, 07:49 PM   #27
Nimble
right, the reader of the joke has to be able to think for the joke to work.
Old 05-02-2007, 11:29 AM   #28
marcus
toyota
marcus's Avatar
well i meant is that we dont get weird comments is here..so i figured u were serious..just trying to help bro..
Old 05-24-2007, 02:44 PM   #29
marcus
toyota
marcus's Avatar
anybody else notice the engine noise on regular gas and less noise on premium..when accelerating
Old 05-25-2007, 10:09 AM   #30
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Every review I've ever read about buzzy engine noises seemed to blame the use of a timing chain. That said, IMHO timing chains are much more desirable than timing belts, despite the noise. Replacing a timing belt (usually recommended ~60k miles) is an expensive to-do, and should you ever have one snap on you, it basically FUBARs your whole engine... pistons and valves get up-close and personal, and all hell breaks loose (literally). Toyota timing chains are so cool, they don't even require maintenance! (or at least that's what they told me about my Vibe/Matrix).
As far as the regular vs. premium, the only difference is how quickly it detonates. Premium burns just a tad slower and more smoothly due to the extra octane molecules tacked on the end of the molecular chain. Regular burns quickly, resulting in more of a "pop" combustion. Maybe that's has something to do with it? If I'm not mistaken, most fuel injected cars have "knock" sensors to detect pre-detonation and electronically adjust the timing to compensate.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 05-25-2007, 10:28 AM   #31
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Just a shot in the dark since fuel and the timing chain have already been disgused- What about the A/C compressor? They can make a whirring sound when the compressor clutch is engaged. Run your car with both the A/C on and off and see if it goes away. Remember, even if your A/C button if off, it is still on if your using the defrost airflow. Turn the fan switch off to be sure the clutch disengages.
Old 05-25-2007, 11:23 AM   #32
marcus
toyota
marcus's Avatar
i dont have my ac on... i may unplugged the battery maybe ecu will reset..otherwise..ill bring it in.. first tank was regular gas 87 octane from dealer..i heard the noise on acceleration but i switch to premium for the next 3 tanks..didnt notice it then..just went back to regular and its quite noticeable..hmmmm engine knocks...id say either timing too advance or antiknock sensor not working. well find out soon enuff..
Old 05-25-2007, 11:29 AM   #33
marcus
toyota
marcus's Avatar
same here!!
got the same thoughts about this.. could be the antiknock sensor not working properly...ill keep you guys updated..
~YR
Old 07-23-2007, 10:57 AM   #34
marcus
toyota
marcus's Avatar
men this noise during acceleration still botherin me. specially when the car is loaded its more noticeable.. doesnt anyone notice this. is it normal due to 105 hp ior is it the timing not adj or faulty air sensor .. anyone??? arghhhhh!! hope the cone filter im putting on soon fixes this. otherwise?
Old 07-23-2007, 02:18 PM   #35
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
I thought u were going to take it to the dealership? did you ever do so?
Don't Milk the Cat!
-Said by me during a game of Cranium.
sherryberry is offline   Reply With Quote
Old 07-23-2007, 02:25 PM   #36
marcus
toyota
marcus's Avatar
i did..
i did they said it sounded the same from the other yaris they have in there,,,*sigh* this cant be normal..
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
anyone use Dynamat/ Be Quiet to deaden exhaust noise? Galavoxx Performance Modifications 9 11-29-2006 04:28 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
