Old 04-03-2018, 01:52 PM   #289
David C
Drives: White '07 3dr LB
Thanks again for the write up, today I just did my brother's car cruise control, after doing mine a while ago shortly after buying the car.
I've been wondering though why did toyota chose to have a non persistent CC function rather than always on like I've seen on other manufacturers. What's the idea behind the on/off design rather than just a standby ?
Old 08-30-2018, 03:21 PM   #290
Yarauto
Drives: 09 Yaris Base model
Recently ran across info from CTScott from 2009 on how to install a “two button” control on an 09 base model Yaris (The only luxury on this car is A/C).
Upon inspection of the D3 connector I found that there is only one black wire coming from that connector (no blue or brown wires).
Does that change the usability factor on this car for the “build my own” 2 button control system?
Thanks for any info you can provide.
Yarauto
Yarauto is offline   Reply With Quote
Old 12-27-2020, 10:28 PM   #291
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
So I read through the entire thread but didn't find a solution my issue (some similar cases but no resolution).
I have an 07 sedan, auto transmission, Canadian car. I went to perform this mod today, only to find that I have a factory wire (pin 40) at the ECM connection but no wire at the D3 connection under the steering wheel. No CC lights in the cluster either. Car has been dealer serviced since day 1.
Anyone else figured this one out?
EDIT:
Found the solution in another thread. The pin 40 wire seizes to exist after the firewall connection (AD4) on the drive side of the vehicle. Weird! See attached photo. Hope this helps someone out because it sure as hell gave me headache.
File Type: jpg DIY Cruise Control Wiring Issue Fix.jpg (132.7 KB, 49 views)
Kasbien is offline   Reply With Quote
Old 05-11-2021, 10:37 AM   #292
KermitAUS
Drives: Yaris 2009
Following.
KermitAUS is offline   Reply With Quote
Old 04-04-2023, 03:43 AM   #293
KermitAUS
Drives: Yaris 2009
Has anyone done this in Australia?
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
