Old 01-01-2013, 11:33 PM   #73
jRoss
Drives: 2010 5spd sedan
I just did an oil change with penzoil platinum synthetic oil and a fram tough gaurd filter. I must ask, what's ur beef with fram? I've always used fram...
jRoss is offline   Reply With Quote
Old 01-02-2013, 06:26 AM   #74
bronsin
bronsin's Avatar
Me too. I dont know whats up with FRAM but I dont see cars on the side of the road with blown engines from using a FRAM filter....
...or car manufacturers warning against using them....
Old 07-28-2016, 07:57 PM   #75
David C
Drives: White '07 3dr LB
Thanks for the write-up, this should be a sticky or at least in the DIY compilation.
Old 09-03-2016, 09:42 PM   #76
cocochannel
Drives: 2007 Red Sedan, made in Japan
I'm using Fram filters (tought and ultra synthetic) and Castrol Syntec from 2007 and no problems.
cocochannel is offline   Reply With Quote
Old 08-02-2017, 02:18 PM   #77
David C
Bump for sticky.
Old 08-02-2017, 08:50 PM   #78
IllusionX
Drives: 07 Yaris Sedan Aero
Wow, this post has been around since 2008. :)
Nothing wrong with Fram except the filter ends inside is made of cardboard, so that might fail, if it does.
I've been sticking with OEM filters as they are cheaper than Fram anyways. But it did happen when I did not have time to get to the dealer, so I just grab a Fram from Walmart.
Else, I've used Amsoil EK filters.
Old 10-16-2017, 08:10 AM   #79
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
I just changed my own oil yesterday after wasting 1.5 hours of my life waiting for a service APPOINTMENT, then telling me they're extremely backed up (Could've gave me a heads up). I went home, jacked it up and changed my own oil/filter in 35 mins. Much easier to DIY rather than drive to a shop then wait. This car is easily accessible for oil changes. I was even able to explain step by step to my eldest daughter as she watched me. I told her this may be her car one day so pay attention. lol
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 05-19-2018, 12:55 PM   #80
IllusionX
Sure, depends on your hands and how big you are.
I'm able to slide under and reach over, but it's hard to remove the oil filter IMO
Originally Posted by BlackTy View Post
Can I do this without raising my car?
Sent from my ONE A2005 using Tapatalk
Old 05-19-2018, 01:32 PM   #81
David C
An easy inexpensive solution I found was to double stack 2 pieces of 2x6 lumber and place them in front of each wheels and drive on them. You then effectively raise the car by 3" off the ground with all 4 wheels leveled and the lumber is strong enough to support the weight of the car. That additional 3" really make a big difference in term of clearance under the car. Cheap and quick, instead of buying ramps that have the car slanted.
Old 01-09-2019, 08:10 PM   #82
IllusionX
Originally Posted by Jboss View Post
What kind of tools do you guys use to remove the oil filter if its tough to get off because of the awkward spot of being under the car? I've seen the one where you can tighten it on the filter, and there's a oil filter cap that you use with a wrench?
Any of these will do.
Sent from my CLT-L04 using Tapatalk
Old 01-10-2019, 01:29 AM   #83
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Lisle 63600 Oil Filter Tool
FunctionSpec is offline   Reply With Quote
Old 01-10-2019, 05:29 AM   #84
dogsridewith
Drives: 2007 2-door hatchback
Oil Change Tools
First change w/ a Lowe's Husky brand all black rubber strap wrench. (Much like the red ones in above photo.) Takes a touch, but this tool is an absolute must for the general purpose toolbox.
Second change filter (white SKS?) has a nice male hex about the size of a lug nut or a bit smaller.
Not ones in photo, but a couple of my cheap cup-type filter sockets were garbage.
Old 01-10-2019, 05:36 AM   #85
dogsridewith
Oil change ramps
On a part of my lawn that slopes just right, I drive the front wheels onto shallow plastic ramps. Vehicle is level. (What I do, w/ chocks and brakes. Not advice.)
Old 01-10-2019, 08:57 AM   #86
Leegamer
Leegamer's Avatar
I've never had much luck with oil filter wrenches. If It's that tight I usually just shove a long flat head screwdriver through the filter and use it for leverage.
I'm a hermit named Lee
Old 01-11-2019, 04:55 AM   #87
komichal
That is a messy way. Filter is full of oil.
Old 01-11-2019, 08:16 AM   #88
Leegamer
Leegamer's Avatar
I have a pan under it, usually not that bad honestly.
Doesn't happen much, I can undo it by hand 95% of the time.
Old 01-11-2019, 07:18 PM   #89
IllusionX
Even with the tool, oil will leak all over the place as there is oil up in the engine as well, and can't be drained.
Yaris oil change appreciation flagmunkey DIY / Maintenance / Service 18 07-19-2007 02:46 PM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 09:32 AM
