#19 | |
Podiatrist
Drives: Turbo IS300 Join Date: May 2006
I am certainly not agreeing with you. If you want to talk about brake clearance: Say you have a 17x7 on a 45 offset...and it happens to have 2mm clearance from the brake caliper. If you take a 17x7 with a 50 offset, it will have the same 2mm clearance from the brake caliper. Offset does not change the hub size. It does not change the hub/face design at all. Offset moves the entire hub/face assembly to a different place inside the rim blank. So if you are rubbing your caliper, getting a different offset wheel doesn't necessarily fix anything. If you throw on a wheel spacer, you are effectively changing the measurement of offset by pushing the hub/face outwards. You are effectively decreasing offset. But then you run into situations where people think that since they artificially changed the offset of the rim setup, that someone else can just run the resulting offset and be fine. An example: a 17x7 with 50 offset wheel doesn't fit because of brake clearance...and you spacered it 5mm. Someone may think now that a 17x7 with a 45 offset should be fine. But it definately is NOT because you are artificially changing the offset and increasing the hub size. |
#20 |
Podiatrist
Either way man, no hard feelings. Not trying to be a dick.
But I think you're giving false info and if people read it and take it as fact, they may be running around with all sorts of fuxored wheel combinations. And that's the worst...to buy a wheel, mount a tire and drive on it only to find out that the suckers don't fit. Wheels are expensive to ship. |
#21 | |
) However, this is why you have to use common sense when chosing a spacer for your wheels. (if needed) If you have chosen a 0offset 15x8.5 wheel for example, you have chosen the wrong wheel for a yaris because the spacer would have to be pretty large in mm's to push the wheel far enough out to clear. As long as you don't go extreme with the spacers, your fine. Ignoring spacers and just going with wheels that clear the first time is obviously the better choice, but wheels spacers doesn't automatically mean wheel/lug failure.
#22 | |
Podiatrist
If you have a 15x8.5 wheel with a 0 offset you are definately not going to need a spacer. The lower the offset, the further it sticks out. |
#23 | |
I'm not trying to argue with you, my main point is to say spacers are a 100% waste of time and dangerous is only valid if you choose an extreme route. You have to choose your wheels and offsets with practical thinking in mind. |
#24 | ||
Podiatrist
I'm just saying that a 0 offset makes the the wheel stick out of the fender...not in. I think you had that backwards. This is what you wrote Quote:
Spacers can only "fix" situations when the wheel sits too far in. If it sits too far out, you're fuxored. In my opinion, the extreme spacers are better because their own pressed in studs making them much more reliable and prone to breaking. Last edited by SophieSleeps; 06-01-2006 at 05:48 PM. |
#25 |
Only Happy When it Rains
Dude, I never said I knew anything.
I only pass on info others have related to me, as I have 0 practical knowledge with automobiles, and I have made that abundantly clear. I think I understand what you are saying. You seem to be saying getting the proper wheel fitment is a heck of a lot harder than it seems. And you are an ass.
Colin Chapman disciple |
#26 | |
Podiatrist
In 3D, i'm a much nicer person occasionally. Sometimes You can look at the pussy
#27 |
Guys, you do realize you are getting upset over talking about wheels, right?
You two need to do this; or and just relax. It's not worth it in person, much less on a forum. |
#28 | |
Podiatrist
So I look at the picture of the pussy. |
#29 | |
toyota
by the way!!
you should be running 205/40/17's Not 205/45/17 .. itll make your diameter slightly bigger therefore lost of acceleration as well...small nicky stuff!!
#30 |
I am runing 215/40/17 and they fit perfect its close to rubbing but I don't have any rubbing except maybe large pot holes when the car is full.
#31 |
toyota
215 wow thats a nice width for the tire.. then put sum spacer on the rear and u got ur self a mini rc racer...heheheh
#32 | |
der Zeck
if you are running a 7 inch wide wheel a +38 off set is what you need... you said you are running a 205 something or other tire?... it is going to be a tad to small but it will be a mile away from rubbing.... I would go with the 215/40R17 get you with the correct rolling diameter, with no rubbing problems... I am running 15X7's with a +38 and I have 225/50R15 no rubbing problems so you will be fine, no spacers and you can have all the fat ppl you want in the back with no problems, I have loaded my yaris down a few times and I am running a MUCH wider setup no problems at all |
#33 |
![]() Drives: 2006 Yaris RS HB Join Date: Jan 2007
#34 |
In my future I see a pair of 17" x 7" Enkey FN-18 with a 42 offset and 205/45R17 tires. I'm pretty much in love with these rims. I already got my DF210's just need to install them. You guyses think I'll have any problem with rubbing etc? I'll pretty much be the only one in the car. I have no fiends
VI VI VI
#35 | |
der Zeck
BTW they are Enkei wheels not Enkey
#36 | |
Haha, I didn't even realize a wrote that, I'll take a slap in the face next time ya see me. I think I posted that around 5 in the morning. I'd hate to have to get them in 16". I haven't seen to many people droppin anything on a Yaris bigger than 17" without havin rubbin problems. Uhm...except that one dude with dubs... So you think spacers would clear up this problem if it becomes aparent?
VI VI VI
| My poor rim | bdiu | General Yaris / Vitz Discussion | 5 | 04-07-2006 07:51 PM |
