![]() ![]() Drives: 2015 yaris hatchback Join Date: Jan 2018
DRL disable
how do i disable the DRLs on a 2015 Yaris Hatchback LE? I viewed the 2007 yaris video but no luck. I removed and checked under the steering wheel assembly towards the stereo but nothing. The fuse wont budge at all.
#2 | |
![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
Sent from my SM-N910F using Tapatalk |
There are no DRL fuse.
Sent from my ONE A2005 using Tapatalk |
#5 | |
2015 DRL module might be located elsewhere as the interior was completely redesigned. Sent from my ONE A2005 using Tapatalk |
why would you disable the DLRs?
I did not. I had them rewired to the fog lamps.
It's technically not legal where I live, but cops don't know. Sent from my ONE A2005 using Tapatalk |
#8 | |
or get the stalk that has the foglamp switch on it and tap your headlight harness. and or look for your connectors I think the yaris is either prewired or can be wired dont ask me how. |
#9 | |
Turn on the headlights, and fogs turn on or off as it should, and turn off automatically on high beam. Sent from my ONE A2005 using Tapatalk |
yeah so why did you disable the DLR's again.
Not disabled. It's always running as it should, cept they are on the fogs instead of low beam.
method doesnt work on mine. once i release the handbrake, drl lights come back on.
| Disable DRL on 2012 Yaris Le | ucsmfu | Third Gen Yaris General Discussion | 12 | 09-16-2015 10:29 PM |
| enable DRL at Yaris 2009-2011 | Ot_tO | DIY / Maintenance / Service | 6 | 06-15-2012 05:13 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
| Disable DRL and keep Fog Light function!! | chino_potato | DIY / Maintenance / Service | 10 | 06-23-2007 01:01 PM |
