Old 08-17-2018, 01:40 PM   #1
max yaris
Drives: 2010 Yaris Hatch
Weird creaking during braking
Hello,
Im experiencing a really inexplicable creaking noise in the brake system. I apply the brakes and it sounds like an oscillating creaking/rubbing noise. Brake pads and discs are brand new and calipers we're fully inspected and cleaned of any rust on sliding surfaces. The rear is in good shape as well, shoes are well worn and springs and levers seem to function normally. I lubricated all the contact points on the backplate and the pivot points as well with silicone ceramic grease. Let me know any of your insights, I'm at a loss here.
Thanks
max yaris is offline   Reply With Quote
Old 08-17-2018, 02:47 PM   #2
tmontague
tmontague's Avatar
does this happen even when not applying brake pressure? If so then your dust shield behind the rotor is likely just pushed in and rubbing the rotor.
If not than I'd check if you have a rock or anything lodged in your braking system
Old 08-17-2018, 02:57 PM   #3
Can a wheel bearing that is starting to go manifest itself with such noises under braking pressure?
Old 08-17-2018, 05:20 PM   #4
max yaris
Thanks for your input, but the sound I'm experiencing is not like a backplate type sound. It's more of a groaning. As the poster after you mentioned, it could be a wheel bearing too, didn't think of that. Will check and chime back in.
Old 08-20-2018, 09:59 AM   #5
Prosight
Drives: yaris
I’ve got the same phenomenon.
I changed the drum “ with a used one”
The noise gone.
Replace rear brake drum if inside diameter is greater then 201mm.
Prosight is offline   Reply With Quote
Old 08-22-2018, 03:29 AM   #6
dblade
Drives: toyota yaris d4d
Hello everyone
I have the same problem with cracking noise when i am aply pressure at the brakes and turn it sound like it rattle the pads into the disks .
The noise is more intense when i am downhill .
I change brake disks and pads at the front with brand new
I have also brake disks at the rear but is like new, any suggestions?
dblade is offline   Reply With Quote
Just got a Yaris - AT downshifts when braking? Jlager General Yaris / Vitz Discussion 6 08-06-2012 05:44 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 08:07 PM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 10:35 AM
Weird issue during braking xtremesniper Canada 21 06-04-2009 12:00 PM
"Tok" Sound when braking at low speeds (less than 10kmph) buchieboy General Yaris / Vitz Discussion 30 02-16-2009 07:50 PM
