Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
DRUM BRAKES
*science garage screaming* DRUM BRAKES.
- Discuss all Drum Brake things here. |
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
DUMB BRAKES.
But seriously, the only reason why manufacturers still use them is because they're cheap, and they do the job. I don't like cleaning them, and I don't like replacing them. Disc brakes rule.
If you lack driver skill, add horsepower. |
#3 | |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
I got 150k miles out of my factory brake pads on the front. I guess I should have a look at the drums. |
feed my pet
They don't oxidize when your parked outside and it's raining
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
But they will seize on if allowed to. I always leave the handbrake of after washing the car, more in winter.
I had a problem last winter when the drums must have frozen onto the drum. It was a nightmare trying to free them. Eventually achieved by driving forwards and backwards on my street. Must have lookd a bit strange to an observer. It threw up ABS and Traction fault warning lights and stored trouble codes them. ![]() Although it's doubtful you will have that problem in Malaysia.
feed my pet
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
![]() ![]() ![]() Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
I dont like them. I try to convert them if i have them on a car.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
You can't beat a drum...er well maybe.
![]() ![]() Drives: 04 3dr HB and 04 5dr RS Join Date: Mar 2018
Zero Drag and a self adjusting parking brake.......for a car as light as the Yaris they are perfect.
As long as I never have to change them or take them apart. ;) |
well i know from experience. any sort of modifications to the master/booster/ front calipers throws the braking feel way off, and the drums are sorta.... inferior to all those
#14 | |
the stuffs not expensive you just need to pull wrecker parts.
#15 | |
![]() Drives: 2016 yaris Join Date: May 2018
Sent from my moto x4 using Tapatalk |
#16 |
drumbrake self adjusters star wheels
Make a lot of foot brake stops in reverse, or adjust the star wheels. Search and read lots of info on this here in yarsisworld.
One peculiarity of the 2nd gens is that a number of reports indicate the self-adjusters don't work very well. (Handbrake develops a lot of clicks.) |
#17 |
With a truck it's easy just to climb underneath and hit the star adjusters, but the Yaris is a little shorter to the ground. I was hoping there was a way to easily adjust them automatically going reverse and pulling the parking brake or going in reverse and hitting the foot brake maybe. Mine's a 2016 if that makes any difference.
I'll try going reverse and stopping a few times see if that shortens pull of the parking brake Sent from my moto x4 using Tapatalk |
#18 |
Automatic adjusters drum hand parking foot brake
The guy here who did it that way said it worked with a lot of stops, not a few. It could be the handbrake works better than footbrake, or worse, or not at all. Since the fronts aren't helping, the rears do all the work. But the clever invention couldn't expect people to stop in reverse with the handbrake.
+1 on hard to reach the star wheels from behind. But the drum usually slides right off...Tercel still required bearing disassembly, I recall. I like to inspect shoes, de-dust, and scrape rust from the edge that can form w/ high miles/use in salt spray. |
| drum brakes make squeaky noise | jack black | DIY / Maintenance / Service | 5 | 08-17-2014 07:45 PM |
| Rear Drum brakes | bankrobber | DIY / Maintenance / Service | 0 | 04-18-2010 12:39 AM |
| Changing drum brakes to discs? | eTiMaGo | Performance Modifications | 5 | 09-25-2006 05:17 PM |
