Old 01-13-2019, 11:03 AM   #91
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Let me try attaching a couple of pictures.
Regards,
DeeBee
DeeBee is offline   Reply With Quote
Old 01-13-2019, 11:06 AM   #92
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
The diode connection is in the first pic. Temporary but functional.
Regards,
DeeBee
Old 01-13-2019, 11:24 AM   #93
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Originally Posted by IllusionX View Post
If you are on mobile, use Tapatalk
Sent from my CLT-L04 using Tapatalk
Thanks heaps
Regards,
DeeBee
Old 01-13-2019, 03:42 PM   #94
fredovvti
Drives: Yaris 07 HB
Thank you!!
Sent from my SM-N950F using Tapatalk
fredovvti is offline   Reply With Quote
Old 01-14-2019, 12:53 PM   #95
fredovvti
Drives: Yaris 07 HB
In this image, you can make more details, I 2 cable connected to the diode. Those are the negative im correct? I see to red taped together what are those?
Thank you for your response.
Old 01-15-2019, 11:52 AM   #96
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Hi fredovvti,
In the image showing the relays, yes, I connected the low beam negative and high beam negative terminals.
The relays are part of a harness I purchased to get the ballasts to turn on. Sadly, in an effort to get this mod working I butchered the harness quite a lot trying to get it to work. I'm not sure I can get it back to the way it was wired when I bought it but it works fine now.
Initially, I connected both negatives and all lights came on, all the time - Not good. Eventually I discovered that all I needed to do was connect both negatives using a diode to keep high beams off during low beam operation and during high beam operation keep the low beams on.
I am very happy with this mod because I can flash to see ahead at a corner without losing the HID wide-angle view.
Regards,
DeeBee
Old 01-15-2019, 12:26 PM   #97
fredovvti
Drives: Yaris 07 HB
Interesting, so it only connwct the negatives wires to the diode. I will try went my extra relay harness arrive. Thank you for the respone.
Old 01-15-2019, 09:08 PM   #98
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
That is correct. The diode only connects the negative wires.
Looking forward to hear how it goes for you once you get your harness.
Regards,
DeeBee
Old 01-21-2019, 01:44 PM   #99
fredovvti
Drives: Yaris 07 HB
Att lastt!! Thanks to Deebee for the help I conquer the hi/low beam in same time. Now I have full jdm lights!!! I connect the diode with hi and low.
Old 01-29-2019, 03:35 AM   #100
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Glad to have been of assistance
I am happy to see it worked for you too
The lights are just amazing
I like the way you connected your diode. I should have done it the same way to save on the time I spent removing the contacts from the relay connectors
Regards,
DeeBee
Old 03-07-2019, 07:20 AM   #101
GPBIG
Drives: Yaris HB 2007
Talking Please Help
Originally Posted by enviri View Post
I conect everething like you said, hi beam work , but no HID . Is save to test the HID ballast with only a positive and negative to the battery?
GPBIG is offline   Reply With Quote
Old 04-12-2019, 12:02 PM   #102
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Interesting Thread....I do not believe my 2010 3D Hatch is Negative Switched...I purchased "Headlight Revolution" H4 LED Headlights and plug and play installed normally last summer... After buying some "No Name" LEDs that also worked normally but had crappy output...Maybe they got rid of that with the DRL?
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 04-12-2019, 12:05 PM   #103
IllusionX
Drives: 07 Yaris Sedan Aero
The cheapest LED headlights bulbs have auto sensing polarity. You can connect whichever way you want it will always work.
Old 04-12-2019, 12:17 PM   #104
BIGTAZ351
BIGTAZ351's Avatar
I will have to check that...Because I also had installed a H4 relay harness when I was running the 100W/130W Halogens (Which I removed when I went to LED) and it worked normally as well...and it was installed into my Chevrolet after the Yaris...and I thought I checked the outputs before I installed that harness...I seriously do not think the newer NON-DRL ones are Negative switched.
(And those H4 were from the motorcycle world, they do not work backwards!)
Repair List:
Mod List:
Old 04-13-2019, 05:14 AM   #105
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
this should help. Power flows as same way no matter if its ground or positive switched. But yes Yaris are ground switched 06-11 for sure.
Check out my Build thread:
Old 04-15-2019, 04:59 AM   #106
BIGTAZ351
BIGTAZ351's Avatar
OK I went out and tested my car...It does feed Backwards...I am curious how the Relays in the HD wiring harness allowed it to work, those relays have a diode in the trigger coil to prevent back feeding? And because I purchased it for a "Normal" vehicle then used it on a "Backwards" vehicle, then installed it on a Normal Vehicle...either those relays work both ways and or the diodes were non-existent... Either Way seems the LED lights have gotten "smarter" than when they first started making them for Motorcycles...they wouldn't work or would "smoke" if you gave them power thru the Ground! (Very Interesting)
(The power actually flows Backwards thru the bulb, This is DC not AC.)
Repair List:
Mod List:
Old 08-24-2019, 09:59 AM   #107
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Originally Posted by DeeBee View Post
Finally, I have success!!
The low beam stays on when I select the high beam
I used a 6A 400V rectifier diode between the low and high beam ground wires connected to the low and high beam relays.
So far the result is what I have been looking for
Thank you all for your help along the way!!!
This was short-lived
My HID's started flickering intermittently
After some investigation I found that the harness I used had started melting connectors Not sure if the diode "fix" was responsible but I was lucky my headlights did not shut off on me while driving on a dark road or highway.
I had to disconnect everything and I'l have to do this install all over again in the summer! I think this time I'll look for one of the Morimoto harnesses that have been great in the past.
Looking forward to bright headlights again....
Regards,
DeeBee
Old 08-27-2019, 04:55 AM   #108
ezhacker1
ezhacker1's Avatar
I too went from diode between the hi and low to Morimoto MotoControl. Best thing ever. But i do hate these housings for retrofitting (Morimoto Mini D2s 5.0) ... my driver side high beam solenoid must have been disconnected. But I have 2 six inch light bars in the grille for high beams that do so much more.
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 11:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 07:30 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 07:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 03:56 PM
