Old 03-27-2019, 07:08 AM   #37
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
They look great! I agree with kimona, get some trim rings. There is also a center cap that would look stunning with the trim rings, though I was never able to find them for sale. I believe they are out there. I just didn't spend a lot of time looking for them.
Old 03-27-2019, 08:41 AM   #38
Maritime
Drives: 2008 yaris 5dr hatch
HA, I was just about to say the black on black is nice but the trim rings may make it even classier. Good job.
Maritime is offline   Reply With Quote
Old 03-27-2019, 12:31 PM   #39
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Yep, much better
On Instagram
On Wheelwell
Old 03-28-2019, 05:16 AM   #40
bentjazz
Drives: 2009 Yaris--3dr MT
Thank you, YWers. If I put on a set of trim rings, I'll post pics. Wish I could find those center caps you mentioned, 06YarisRS. I just hope my paint job lasts awhile.....don't want to be painting wheelies again anytime soon.
bentjazz is offline   Reply With Quote
Old 03-28-2019, 07:36 AM   #41
06YarisRS
If you dig back in the wheel threads, I think there's a pic or two of the caps I mentioned. You might find a lead there.
Your paint should last a good while, but it would be good to have a little touchup paint on hand. The areas that will be most affected is where your wheel weights attach and at the very lip of the rim. If you're not wanting to spray the entire rims with rustproofing, at least give those wheel weights a spray, then wipe off the excess. It will penetrate under the weights and protect where the paint gets scratched off.
Old 03-28-2019, 05:03 PM   #42
bentjazz
Thanks, 06YarisRS. I need all the tips I can get!
Old 03-28-2019, 05:09 PM   #43
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
yea looks great
love the 2 door model
Old 03-28-2019, 05:09 PM   #44
bentjazz
06YarisRS, what do you mean by rustproofing the entire rims? Would that entail spraying the rims with paint when a scratch occurs, etc? That sort of thing?
Thank you!
Old 03-28-2019, 05:10 PM   #45
bentjazz
Thanks, justanotherdrunk!
Old 03-28-2019, 05:32 PM   #46
06YarisRS
Thank you!
Not paint, just a light mist of rustproofing. After a few applications, a nice protective layer builds up. I usually degrease them in the spring and start over.
Old 03-28-2019, 06:35 PM   #47
bentjazz
06YarisRS, do you have a recommendation for a rustproofing product I should use? I'm assuming it's a spray, right? Thanks.
Old 03-28-2019, 08:30 PM   #48
dogsridewith
Drives: 2007 2-door hatchback
Toyota and Miata steelies are two pieces welded together. I oil the crack where they meet w/ Corrosion Block. The powder coater who did this Yaris' Miata rims in body color said rust first originates from this joint...that he shoots a bead of silver caulk on the various steelies that he paints silver.
The Yaris original 14" steelies got snow tires and Tercel plastic center caps that I paint w/ chrome rattle can. The Miata 14's get summer tread and have their mini chrome plated steel center caps w/ a Mazda symbol in the center.
Old 03-28-2019, 09:21 PM   #49
06YarisRS
Since Rust Check isn't available in the USA, you might try a product like LPS-3 or Corrosion Block like dogsridewith mentioned.
Old 03-29-2019, 06:13 AM   #50
bentjazz
Thanks so much, guys.
Old 03-29-2019, 07:40 AM   #51
IllusionX
Drives: 07 Yaris Sedan Aero
Wow that's a nice job. I've done mine a few years back as well. Now they are all rusted again lol
Sent from my CLT-L04 using Tapatalk
Old 03-29-2019, 08:27 AM   #52
06YarisRS
Yes, hence the need for rustproofing. Anything short of rustproofed OEM wheels and you're probably looking at 2 years before the blight is underway. Most aftermarket wheels have a very thin coat of cheap spray paint which is very short- lived. I've actually degreased and painted brand new aftermarket steel wheels before even installing them. Also, before I leave the store, I roll the rims on the floor. I've see ones that are not even straight from the suppliers.
Old 03-29-2019, 05:36 PM   #53
bentjazz
I'm definitely going to rustproof these rims. The last thing I want to do is do what I just did with these steelies anytime soon. Thank you for the info guys.
Old 04-04-2019, 04:17 AM   #54
bentjazz
Has anyone used Fluid-Film to rustproof their steelies? Thanks.
Hubcap question 2009 Yaris Sedan- URGENT mrs_yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-13-2016 03:21 PM
09-12 Toyota Yaris Hatchback / Sedan 8 Spoke 15" Hubcap needed! ard2014 Willing to Buy by private party 0 06-11-2014 05:16 PM
08 hubcap ryota Willing to Buy by private party 0 03-11-2013 10:08 AM
Hello! I need at least one hubcap for a 2009 Yaris Sedan txprsn Willing to Buy by private party 2 05-15-2010 05:56 PM
WTB: Hubcap and Grille LoadThis Willing to Buy by private party 9 11-05-2009 12:09 PM
