Old 05-04-2019, 02:17 PM   #55
sven337
Drives: Yaris
Just replacing the transistors doesn't seem to work (because they'll die again soon), so let's figure out what they're for exactly and take a higher level look: what is being implemented here?
The way they're connected, the six of them are basically in parallel and drive the cathode (the horizontal filaments) of the VFD. Their job is to get a steady 300mA through these filaments (full brightness, figure empirically found with a bench power supply).
In fact, you can remove the 6 transistors, and connect a constant-current power supply set to 300mA between the + and - (leftmost and rightmost) pins of the VFD, while it's plugged into the board - it will work normally.
I couldn't fully work out how the transistors were driven (=what their base is connected to), but it all goes back to the mainboard and a, on the power board, a pin that seems to be used to dim the VFD. I don't remember it dimming when turning on the headlamps but maybe that's actually what happens. I'm about to lose that feature anyway.
So, instead of trying to fix this broken cheap power supply with such a terrible efficiency that the transistors dissipate multiple watts (about 500mW each, which is not nothing for SOT-89), let's just replace it with something that works better. My theory for why the repair isn't working is that this design relies on the board helping to dissipate some heat, and when it's as badly burnt as mine it doesn't dissipate as well. Of course as soon as 1 transistor dies the rest will follow due to the parallel design. Crappy power supply design that saved maybe 2 bucks.
My plan is to find a buck module with a 2.5V output that I can use as a constant-current device, or if I can, add a series resistor to limit the current to about 300mA.
Then I'll rip out the 6 transistors and connect the buck module where I need it.
sven337 is offline   Reply With Quote
Old 05-05-2019, 09:59 AM   #56
sven337
Drives: Yaris
OK, this is fixed! Hopefully this time for good.
I had an adjustable MP1584EN-based buck module ("D-Sun" chinese brand).
These super common modules you can find for a few dollars.
For example:
https://www.ebay.fr/itm/Ultra-Small-...-/322408214136
I used my poor man's lab power supply to test what were the minimal voltage and currents needed to obtain full brightness, and I found out that a constant voltage 1.5V supply would yield a steady 300mA current that would correspond to full brightness. Going to 2.5V would increase current to 450mA without any visible change in brightness, and starting at 4V the filaments would glow red.
(Sorry about the quality of my pictures, I was focused on solving the problem and only took the pics as an afterthought).
https://perso.aquilenet.fr/~sven337/...test_setup.jpg
https://perso.aquilenet.fr/~sven337/...k/halfwatt.jpg
https://perso.aquilenet.fr/~sven337/.../2halfvolt.jpg
Once this was proven working, I cleared some space on the board by removing the transistors and their base and emitter resistors.
https://perso.aquilenet.fr/~sven337/...cleanboard.jpg
Laid out a layer of tape to insulate, soldered the module and taped it in place. This fits with room to spare when reassembling everything.
https://perso.aquilenet.fr/~sven337/...lock/final.jpg
Sorry that final picture is so anti-climactic.. Everything works quite well for now. I hope it lasts, this time, but see no reason why it wouldn't.
Old 05-06-2019, 02:54 AM   #57
TeeThree
Drives: Yaris T3 5 dr 2006
Thanks for the feedback Sven. I'm confident you may have found a lasting solution to the problem. I will look into the DC-DC converter - a nice neat solution.
Would something like the old LM317 work as well? I already have that in my box of spare parts.
If i set the LM317 to 1.5v this should be ok from what you have discovered from measurements.
Thank you for your effort and feedback.
TeeThree is offline   Reply With Quote
Old 05-07-2019, 03:05 PM   #58
sven337
Drives: Yaris
Electrically it will work. Thermally I'm not so sure. LM317 is a linear regulator so in order to deliver 300mA@1.5V it will draw 300mA@12V and dissipate the difference, which is 3.1W.
The TO220 LM317 datasheet mentions a thermal resistance of about 40°C/W, so you're looking at 120°C over ambient temperature for a device with a maximum operating temperature of 125°C. That's why the original board had 6 transistors...
I wouldn't attempt it. A buck regulator has a better efficiency.
The LM317 is supposed to have thermal protection so it will likely shut down without burning too many things, but if your board is like mine any heat is too much heat.
Old 05-07-2019, 03:09 PM   #59
sven337
Drives: Yaris
Originally Posted by Kaanktm View Post
Could you please inform about the circuit connections on the board.
Are you asking about how to connect the buck module I had to the board? Assuming you have the same, but all buck modules work the same way anyway, you have three leads to connect: Vin, Vout, and GND.
If you look at my very blurry (sorry..) last picture, you can see two red wires and one black wire (at the bottom)*come out of the module. The black wire is GND, and I've taken it at the GND of the capacitor that is next to the blue inductor.
Vin was the + of this capacitor (I think the capacitor/inductor/diode here are an input filter, all I really care about is that there's a constant 12V power supply available there and it was the input of the NPN transistors).
Vout is the leftmost pin of the VFD connector (all 4 left pins are connected together).
I hope this helps you
Old 05-12-2019, 01:17 PM   #60
adsb
Drives: Yaris 1.0 t3
Has this repair held out for you so far sven337 ?
adsb is offline   Reply With Quote
Old 05-12-2019, 02:01 PM   #61
sven337
Drives: Yaris
Because I got the question in private multiple times:
- buck modules are not insulated so they have a single ground - no need to connect both ground wires, any of the two will do
- yes, the repair is still holding out, and I've got a good hope that it will hold forever because I think it's "clean"
Do note that you need to remove the transistors (and while you're at it the emitter and base resistors to make room) before connecting the buck module.
Old 05-12-2019, 02:43 PM   #62
adsb
Thanks sven337,
So the wiring is like this
The 12v feed to the module derived from smd capacitor c535 (470uf/25v) and the dc, aprox 1.5v out (adjust via potentiometer) goes to the left hand pin 1 of the VFD.
Many Thanks again for your help.
Old 05-12-2019, 05:03 PM   #63
sven337
Drives: Yaris
Correct
Old 05-14-2019, 09:22 AM   #64
sven337
Drives: Yaris
That is correct, my instructions didn't cover it but the VFD is held in place inside the white plastic part by its top, you have to slide the top first and then press down the part with the pins to get it back in the white plastic part.
But, you don't actually need to remove the VFD from the white plastic part for this fix, what you need to do is separate the white plastic part from the board which my instructions do cover, albeit without drawing attention to the need to ensure that the VFD pins are correctly connected upon reassembly (it's just a matter of pressing hard on the VFD itself).
Old 05-18-2019, 03:27 PM   #65
adsb
Hi all,
I have the buck module on route from China and hope to complete this modification/repair in the next few weeks.
Can someone explain what this fragile VFD white plastic frame looks like.
I take it that we are dealing with the small VFD and is this "frame" part is the frame which holds the whole clock/warning light pcb to the rest of the instrument assembly ? Hence "many clips" in svens dis assembly guide.
I am looking on this thread for a photo of the frame to identify it but all i can see is a small black frame /surround fitted to the small clock VFD.
Thanks guys.
Great fix btw !
Old 05-20-2019, 07:45 AM   #66
sven337
Drives: Yaris
Don't worry about it. Can't miss it when you disassemble, it's the largest plastic part and the only one colored white. And there's nothing to be careful about really, just to know that when you separate it from the black part at its back, it will disconnect the VFD, so don't pull sideways. And after you clip the black part back on (don't push sideways...), you'll need to push on the VFD (it's glass, you can push hard) to make sure its pins are connected.
Old 05-27-2019, 05:46 AM   #67
adsb
Thanks sven337, I see the white part now, it is pictured in post #48 of this thread, it looks like a support frame to hold the main pcb board.
From the descriptions the white frame holds the VFD display module and the main pcb and when you separate the frame from the main PCB the VFD stays in place on the white frame as it has a slot and a pair of clips to hold the VFD module.
Then its a case of unclipping the VFD from the frame and plugging it into the bare socket for testing/wiring up. Plugging in the VFD provides a load so that the buck module output voltage can be adjusted properly (with a load attached).
I take that the buck output wire is stripped back a few mm at the VFD socket end and the bare end is pushed into pin #1 of the socket receptacle? (The male pin of the VFD holds the wire in place when the VFD is placed back onto the white frame and its all pushed back together).
Did you have any diffculty in removing the SMD components ? Lead free solder is a pain sometimes.
I can see this as a really good fix as the MP1584 based modules run at much lower temperatures than others.
Still waiting for my package from China (buck module)
Old 05-30-2019, 03:00 PM   #68
sven337
Drives: Yaris
It's a buck module, not a linear power supply, you can adjust it without a load.
The VFD is only useful for testing, if you're doing my repair you don't need it you just need to set up the buck module for about 1.5V.
Removing the SMT components is easy. Chisel tip, 30W or more, add a bunch of leaded solder, heat up like crazy (you don't care you're removing everything) and the transistors will slide right off.
As for the VFD socket, I actually soldered the output lead of the buck module to the base of the VFD connector. Not soldering sounded like a potential issue with vibration.
Old 06-09-2019, 03:41 PM   #69
adsb
Right hand drive model repaired, thanks to sven337 for the instructions.
Photos of MP1584EN device, testing with DMM to obtain correct output of 1.5v, more photos of the existing transistors and after removal (a few pads came off in the process) , close ups of buck regulator in situ and wiring to pin 1 of VFD connector.
I disconnected the battery negative terminal before removing cluster.
Used a 12v 1.2ah battery from commercial intruder alarm panel as poor mans lab psu for testing.
I noted that there were 5 transistors not 6 for my model.
That ribbon cable is a right PITA to get back in to the slot and close the latch on the connector !
Sorry if the photos are in the incorrect order.
Thanks again sven337 !
Old 06-29-2019, 09:38 AM   #70
sven337
Drives: Yaris
Thank you for the excellent pictures that will, no doubt, help people implement the fix.
Old 08-13-2019, 10:40 AM   #71
NOLF
Drives: Yaris 1.0
Sorry but i can find dashboard pinout, can you post it for me. I can't test me dash, i don't no where is positive and negative.
NOLF is offline   Reply With Quote
Old 08-14-2019, 05:33 PM   #72
sven337
Drives: Yaris
+12V top right
GND bottom left
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 08:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 04:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 09:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 06:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-09-2009 11:33 PM
