![]() Drives: Yaris T-Sport Join Date: Sep 2018
Lowering on 17’s
Is it possible to lower a yaris hatchback (mk2) that’s on 17in rims, without any fender modification?
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
I'm on 17s, depends on the offset really. I believe I'm on a +42 offset, I "borrowed" these rims from my brother after he got new rims so I'm not 100% sure the offset. They were on a 94 integra before I "borrowed" them. Without rear spacers, the back never rubbed. With the rear spacers (I think I have 10mm Penguin spacers...been a while since I bought these) I had to roll the fenders and I still rub every now and then. Front rubs on occasion depending on how low you go. For reference, I have absolutely no gap between the tires and my fender. I'm on 194/40 Yokohama S.drives.
Definitely possible. As heeroyuy01195 points out, rubbing is another story.
Thanks for the replies guys, but on second thought the gap is really not that big with the stock suspensions and stock 17’s that my hatch has.
Might start learning towards spacers and/or different rims instead. |
![]() Drives: 2010 Yaris Hatchback Join Date: Jun 2019
I wanna see how it turns out. I know it's possible but I haven't seen an actual one.
It's really not that big of a deal, guys. I've ran two different sets of 17" wheels, it's all my car has ever rolled on. With stock suspension, I had zero rubbing. It's at least a four finger fender gap. Looking back at it, GlacierMafia, the wheel gap is really big. I should have lowered my car years before I did.
Once I lowered a couple inches, I started getting a little rubbing over really big dips at higher speed but there are people that run 18s on these cars. Depending on suspension, you're going to have to deal with some rubbing but it's not that crazy. If you plan to track the car, you probably shouldn't go bigger than 16. |
| wheel size with lowering springs | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-18-2015 05:32 PM |
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| Lowering or Not? | chrisj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-06-2010 02:34 PM |
| Lowering options??!! | alan1828 | Canada | 27 | 05-09-2010 01:14 AM |
