Old 12-30-2018, 10:45 PM   #73
kimona
kimona's Avatar
Drives: 2014 White VITZ
Not a big fan of the boxer sound, but I must say it looks outstanding!
Old 01-01-2019, 01:03 AM   #74
Yeah, the UEL header sound is a love it or hate it kind of thing.
I was about to start replacing her speakers, but then thought against it since I barely drive her these days with my work schedule making me miss all of the local meets, plus they're doing a lot of road construction here leaving the freeways heavily uneven (I've been launched off my seat almost hitting my head on the roof, I've seen cars spark from bottoming out, etc). So unless my schedule changes and they're done with all this crazy road construction, I won't be driving her much. So I'm not going to start focusing on the audio, and will just continue with the exterior mods. At least I'd be able to appreciate that when even I go into the garage, unlike new speakers
Old 01-01-2019, 01:09 AM   #75
Plus, Toyota has the speakers wired weirdly. The dash speaker and tweeter are 4-ohm speakers, but wired in a way that the HU sees a 2-ohm load. And if you disconnect one, the other will not work. The door speakers are 2-ohm, and I really don't care about the rear speakers since they're pretty much useless to have in this car. If I ever get to replacing the speakers, I might disconnect and remove the dash speaker and tweeter, and replace the door speaker with a higher end component set up and run new wires to the component tweeter that would be mounted in the dash. Although 2-ohm component speakers are pretty pricey.
Old 01-01-2019, 08:41 AM   #76
IllusionX
Drives: 07 Yaris Sedan Aero
?? You get 3 way speakers in the front?
I know Toyota HU are 2ohm stable because they wire tweeters and front door speakers in parallel.
If you have 4ohm doors then dash+tweeter might be wired in series, and then all this wires in parallel with the door.
Sent from my CLT-L04 using Tapatalk
Old 01-01-2019, 02:13 PM   #77
For the FR-S (not sure which other Toyotas or Scions), they use a 3-way component set up plus two rear speakers. The doors are 2-ohm 6.5" "subwoofers" powered by the OEM amp. I believe they're just regular woofers with a passive crossover tho. They do not sound that good since the bass produced isn't clear no matter where you put the bass level at on the HU. The dash consists of a 4-ohm 3.5" mid-range woofer paired with a 4-ohm 1" (or was it 1.25") tweeter powered by the HU. The rear speakers are 4-ohm full range speakers with a HPF via the HU and is primarily used for rear fill.
Old 01-01-2019, 08:59 PM   #78
She got a MUCH needed brake fluid flush today. Brakes start as soon as I apply the brake pedal now! I had extra left, so I just swapped out what ever was in Dory's reservoir with the extra.
Old 03-30-2019, 06:56 PM   #79
Bought the Nur Spec kit back in December, finally got around to installing it now.
http://www.ft86club.com/forums/showthread.php?t=133769
Old 03-30-2019, 07:00 PM   #80
Also, I'm lazy to put back the pictures from the older posts. Not sure where they disappear, maybe it's because facebook keeps changing the link? Anywho, just refer to my facebook album:
https://www.facebook.com/lazandro.sa...3864368&type=3
Old 04-14-2019, 08:48 AM   #81
zimmer
Drives: 2011 Yaris Sedan
Sweet mods man, nice!
zimmer is offline   Reply With Quote
Old 04-14-2019, 03:59 PM   #82
Thanks!
Old 06-23-2019, 05:26 PM   #83
Drove her down to Santa Nella and Hollister, and took some pics. Only used half a tank of gas, was hoping to burn more.
Old 06-23-2019, 05:32 PM   #84
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
nice mini roadtrip
Old 06-23-2019, 05:54 PM   #85
Originally Posted by justanotherdrunk View Post
nice mini roadtrip
It's like taking one step compared to the trips you take. lol
Old 06-24-2019, 11:32 AM   #86
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
So clean.
On Instagram
On Wheelwell
Old 06-24-2019, 11:08 PM   #87
mondbennet
Drives: 2010 Yaris Hatchback
That looks so clean and stunning.
mondbennet is offline   Reply With Quote
Old 03-19-2020, 04:44 AM   #88
Update: I will be selling Snow White once I get the title in the mail. I'm still figuring out the details on pricing.
Old 03-19-2020, 10:01 AM   #89
http://www.nooooooooooooooo.com/
Old 03-20-2020, 07:12 PM   #90
ern-diz
ern-diz's Avatar
LOL!
On Instagram
On Wheelwell
1.5" Lower front & back: Snow issues? jmanous Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-28-2016 12:14 PM
white plasti-dip and white yaris bcuzau Third Gen Yaris General Discussion 4 07-20-2014 11:19 AM
My wheel dreams crushed or, how heavy is too heavy? Yaristeve Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 12-18-2012 07:06 AM
toyota belta jdm customize 2007 POLAR WHITE pic toyota-belta Photo-Video-Media Gallery 24 09-30-2007 03:36 PM
