Old 06-09-2021, 08:32 AM   #1
yaris4eva
Drives: toyota yaris RS
Knock when warmed up...
Hi guys i have began noticing a faint knocking when my car is fully warmed up, this happens only when car is idling.. it idles quite low @ 600rpm. Plugs are new, pcv, vvt solenoid..oil fully synthetic mobil1 5-30 .. the car is an RS 2011 with only 71 000kms..
Anyone ..
yaris4eva is offline   Reply With Quote
Old 06-09-2021, 08:46 AM   #2
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
Make sure it is actually the engine. My bottom alternator bolt had worked itself slightly loose once and the slight movement of the alt on the bracket sounding exactly like a knocking engine at idle.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 06-09-2021, 01:28 PM   #3
yaris4eva
i did the test removed the serpentine still that faint background knock... but when the hood is closed you dont hear it... i filled up with very high octane booster and it started this...
Alternative to Rod Knock?! atomic_hoji DIY / Maintenance / Service 18 03-19-2019 08:27 PM
Poor gear shifting, Knock sensor code and poor idle running at cold temperature Olusegun25 General Yaris / Vitz Discussion 2 06-20-2016 12:53 PM
Toyota Yaris Hybrid 2015 Knock Sensor imz General Yaris / Vitz Discussion 0 06-11-2016 09:43 AM
Rod knock or Main bearing knock? jabranko General Yaris / Vitz Discussion 27 08-05-2011 12:14 PM
reg or mid dg4rez Fuel Economy Forum 18 11-24-2008 03:13 PM
