Old 08-16-2022, 05:16 PM   #1
yaris4eva
Drives: toyota yaris RS
tok when i press the brakes...
its making a toking noise when i press the brakes..Anyone here experince this ? Thanks
yaris4eva is offline   Reply With Quote
Old 08-16-2022, 05:20 PM   #2
What the hell is a "toking" noise? I know what someone toking a joint sounds like but I imagine your trying to convey something totally different.
Old 08-16-2022, 05:49 PM   #3
Find a place where you can drive at walking speed with someone walking along beside the car as you brake. Try to at least identify which wheel(s) are the source of the noise.
Old 08-16-2022, 07:23 PM   #4
yaris4eva
its on the drivers side... the minute i hit the brake pedal.... end link maybe, stabalizer bushings.... ??
Old 08-24-2022, 09:54 PM   #5
toyotavios_11
Drives: Toyota Vios
replace with new pads, old pads are worn out
toyotavios_11 is offline   Reply With Quote
Old 08-25-2022, 12:37 AM   #6
tigerpaw
Drives: 2012 yaris sedan
Yes, I've had this noise before like TikTok without the Tik, just the Tok. I don't know why it makes this noise but I believe it's harmless. I drove with the same noise for quite a while with no I'll effects. I think when the pads eventually need changing a good mechanic can tell you exactly what the noise is. In my case I would not have driven the car had I thought it was even remotely dangerous. Good luck. Try bleeding the brakes it may work.
tigerpaw is offline   Reply With Quote
Old 08-25-2022, 12:43 AM   #7
tigerpaw
Also try bleeding the brakes, it might just do the trick.
Old 08-25-2022, 08:49 PM   #8
yaris4eva
the problem is fixed...it was the slide pins.. the rubber around the bottom pins were slidding out. I bought new rubbers(view pic), installed, greased and now very smooth.
Old 08-25-2022, 08:51 PM   #9
yaris4eva
pic..
Warning: working on brakes? Don't do this! Yarflana DIY / Maintenance / Service 18 09-14-2019 01:53 PM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 03:20 PM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 01:04 AM
