Old 09-05-2022, 04:44 PM   #1
yaris4eva
Drives: toyota yaris RS
engine chatters..
my engine makes this chattering sound for like 3 or 4 seconds on cold start up... anyone ??
yaris4eva is offline   Reply With Quote
Old 09-05-2022, 09:36 PM   #2
bronsin
bronsin's Avatar
Sounds like oil starvation. Do you have the correct oil filter and viscosity?
How’s the oil Level?
Old 09-06-2022, 01:46 PM   #3
yaris4eva
oil level is perfect... filter oem... the oil is full synthetic mobil 1
though my garage has a slope... maybe the slope??
Old 09-16-2022, 10:24 AM   #4
bronsin
bronsin's Avatar
How many miles on the engine? My Ford F150 engine had a damaged cam chain tensioner. It made the same noise. Although I doubt the engine of your car has the same problems.
It might be the slope. If you park it on the level does it do the same thing?
Old 09-20-2022, 09:57 AM   #5
yaris4eva
when it stays outside in the heat starts very smooth.. but my garage is very humid and has a slope... it will chattter for a few seconds... engine has 77000kms.. im in Canada.
Old 09-20-2022, 11:29 AM   #6
bronsin
bronsin's Avatar
Well if it had a bad mechanical problem it would make noise even starting it outside where its level. I guess something must be wrong that would take more sleuthing to figure out.
But it doesn’t seem drastic I’ll give it some more thought!
Old 09-20-2022, 11:34 AM   #7
bronsin
bronsin's Avatar
If you wanted to avoid the noise you could just park it outside on the level. Does it shatter when it’s cold outside but not when it’s warm outside?
If you drive to the store does it Chatter after the engine has warmed up?
Old 09-20-2022, 03:48 PM   #8
yaris4eva
when the engine is warm its very smooth... all i can hear are a little bit the lifters...but dealer said its normal....
Old 09-20-2022, 04:57 PM   #9
bronsin
bronsin's Avatar
Lifters? Hydraulic lifters? These engines don’t have hydraulic lifters. They have shim under bucket valve adjustment. They are exactly like high-performance motorcycle engines. The adjustment is supposed to be made every 60,000 miles. Or should I say checked and adjusted if needed. Which is very involved and almost never done. I’ve never read in this form of it being done.
My wife’s 2005 Camry with 196,000 miles has the same arrangement and the valves have never been checked and certainly never adjusted.
Which probably has nothing to do with What you are experiencing! No noise when starting warm, but a brief clutter when cold starting. On a slope not on level ground.
If the dealer Toyota has examined The car there’s probably nothing drastic wrong. I guess it’s just one of those things it would be nice to know the answer to, but noT really practical.
Having said all that ...
In 1980 we bought a brand new Subaru hatchback for $4600 bottom line. When I change the oil and use the fram Oil filter, the engine clattered on start up hot or cold. I had to buy the oil filter at Subaru to fix that problem. But in your case your oil and filter are all in spec.
Maybe someone else could jump in at this point?
Old 09-21-2022, 08:20 PM   #10
yaris4eva
I have a small video of engine on idle and you can hear the lifters and injectors... its a funny sounding engine.. How can i post the video or should i email you the video.. its a short viveo under one minute. It also says on the oem sticker under the hood.. that the engine needs no adjustments.
thanks
Old 09-22-2022, 05:55 AM   #11
bronsin
bronsin's Avatar
Where it says quick reply quick on go advanced. Then click on attach files and follow the instructions.
Old 09-22-2022, 05:35 PM   #12
yaris4eva
i tried it says file cant be reached,,,, oh well
Old 09-22-2022, 09:39 PM   #13
bronsin
bronsin's Avatar
I’m sorry not attached files press manage attachments
motorbike engine swap ACKING_QC Performance Modifications 6 05-12-2021 04:08 PM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 10:34 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
