Old 04-19-2022, 01:13 PM   #1
ltwargssf
Drives: yaris
Lightweight crank pulleys?
Looking to maybe put some lightweight pulley on my Yaris but I'm a bit hesitant about reliability since I drive this car over 40k a year.
There doesn't seem to be many options for the 1nz, so far my options are a vividracing or AROSPEED on ebay.
https://www.vividracing.com/nonstopt...151673703.html
Has anyone had experience with these parts and the quality? I'm also worried about the stock pulley being a harmonic balancer and potentially putting wear on the crankshaft if I remove that balancer. If so, I am debating if this is more of a "race car" mod rather than long-term reliability.
ltwargssf is offline   Reply With Quote
Old 04-19-2022, 03:10 PM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
In my experience it didn't do much, better invest in lightweight flywheel
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 04-20-2022, 01:34 AM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
I have the NST crank pulley on my car, its definitely more responsive and heel-toe downshifting is a breeze.
The downside is that there is less rotating inertia so you have to slip the clutch a bit more to get going smoothly, not a big deal if you're a competent manual driver.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-21-2022, 10:37 PM   #4
remcafee
i would recommend not doing light weight crank pulleys, they dont have any harmonic dampening, so you will ruin your crankshaft bearings prematurely
Old 04-21-2022, 11:41 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
1NZ-FEs aren't internally balanced?
2014 NCP131 5 Speed
Old 05-25-2022, 08:21 AM   #6
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
There is no harmonic balancing on the Echo, the engine must be internally balanced.
Ronnie V is offline   Reply With Quote
Old 05-25-2022, 08:53 PM   #7
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Yari' use the same crank pulley as the Echo despite them only using one accessory belt.
2014 NCP131 5 Speed
Old 02-25-2023, 01:35 PM   #8
SirDigby
Drives: 2007 yaris 3 door
NST crank works okay for N/A. they will break under pressure. (+5 years)
NST water pump pully DOES NOT work. the belt eats through the thin aluminum (6months)
NST alt pully works fine. you save 2g or whatever. not worth paying for IMO.
Old 02-25-2023, 08:43 PM   #9
Compeer
Drives: NCP90 TRD Yaris Manual
There is also https://www.worksengineering.co/prod...oyota-vios-1-5
Compeer is offline   Reply With Quote
WTB: MI lightweight crank pulley cwitte Willing to Buy by private party 2 06-24-2015 11:48 PM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 07:57 AM
Lightweight Crank Pulley axiom Performance Modifications 16 09-01-2014 10:29 PM
NST crank pulleys 15% off cali yaris Micro Image 0 08-19-2010 06:28 PM
Crank pulley's for Yaris? ToTo Performance Modifications 12 03-04-2007 05:42 AM
