Old 03-13-2023, 06:31 PM   #19
remcafee
i managed to get off the old adhesive, man that was tedious and a pain! i got all new rubber lip moldings and i did not get toyotas one because they come gray, i instead picked up a roll of hondas molding it comes in black, should look really goodhttps://www.yarisworld.com/forums/attachment.php?attachmentid=62562&stc=1&d=16787466 55
Old 03-13-2023, 07:20 PM   #20
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by remcafee View Post
i can tell ypu that mine does not have that gap, is that a toyota grille or aftermarket? mines the toyota one so it sit flush, i took it apart already and painted it black but i remember for a fact there was no gaps, heres my grille how it turned outhttps://www.yarisworld.com/forums/attachment.php?attachmentid=62560&stc=1&d=16787463 82
does yours have this part number on the back?
https://www.yarisworld.com/forums/at...1&d=1678746382
Mine might be aftermarket. I don’t remember if the number on the back says Toyota. What I’m wondering is does yours look the same, or do I need to trim mine along the bend (marked in red).
File Type: jpg 61B5306A-D714-409C-B1C2-25685DFF730E.jpg (116.4 KB, 101 views)
Neinris is offline   Reply With Quote
Old 03-15-2023, 01:23 PM   #21
remcafee
heres mine
https://www.yarisworld.com/forums/at...1&d=1678901003
Old 03-15-2023, 03:31 PM   #22
Neinris
Hmmm... yours has that lip too... I'd have to see if I mounted mine correctly.
Thanks for taking a pic!
Old 03-15-2023, 03:43 PM   #23
remcafee
you are missingthe rubber molding it looks like, the factory has that rubber molding around it maybe that fills in the gap
Old 03-15-2023, 04:01 PM   #24
Neinris
Oh... I wonder if I can buy that separately? Would you mind testing yours out without the rubber and see how it looks?
Old 03-15-2023, 04:39 PM   #25
I'm thinking the issue here is trying to use a JDM grill insert on a USDM bumper cover. JDM bumper cover is shorter which means it does not have the same curvatures as the USDM.
Old 03-15-2023, 07:37 PM   #26
Neinris
remcafee, would you mind testing this theory on your USDM bumper?
Old 03-16-2023, 02:53 PM   #27
remcafee
if i have the time i will, i got a track weekend im doing so it wont be anytime this week, im going to install the lip kit today and hopefully it all goes smooth, i had to repaint it 4 times i wasnt happy with my results, finally i got it to where i am happy, its tricky to prep the surface on it as its flexible plastix
Old 03-16-2023, 03:41 PM   #28
sh0rtlife
flex aditive is fun isnt it..and it screws with the mix of the paint thus throwing off your gun adjustments
Old 03-16-2023, 06:52 PM   #29
remcafee
exactly, its hard to match with the rest of the car paint, i went ahead and added a little slight more yellow tint to my mix and its as close as its gonna get, i respect all painters, its very hard to do, especially if you want a good finish
Old 03-17-2023, 09:57 AM   #30
Neinris
Whenever you have the chance. Thanks in advance.
Old 03-19-2023, 09:13 PM   #31
remcafee
https://www.yarisworld.com/forums/at...1&d=1679274710
Old 03-20-2023, 02:46 PM   #32
Neinris
Nice!!! Are the side skirts even with the pinch welds? I don't want side skirts much lower than that.
Are you going to install the top grill too??? Look for a spoiler, even if they are replicas...
Old 03-20-2023, 09:33 PM   #33
sh0rtlife
id rock that.....did you lose and ground clearance on the nose?...looks like you did and didnt at the same time
i want the rear bumper bit most of all
Old 03-21-2023, 10:20 PM   #34
remcafee
it sits about half inch lower than the pinch welds i say, front lip in the middle is about even then it flares out the sides, same with rear the middle is about even with bumper then flares out lower to sides
Old 03-21-2023, 10:23 PM   #35
remcafee
i debated the grille and after looking i think the stock one looks better in my opinion
Old 03-22-2023, 09:17 AM   #36
Neinris
try painting the boarder white, and leave the inside black, see how you feel...
stock yaris s oem lip kit? where can i look s2dannyk Cosmetic Modifications (Exterior/Interior) 6 01-26-2012 06:22 PM
WTB 2010 Liftback Blazing Blue OEM S Lip Kit bad_bwoy007 Willing to Buy by private party 0 01-24-2012 08:43 AM
ANYONE SWAP 2010 LIP KIT ONTO AN 07-08 YET? BLAZINBLUEVITZ Cosmetic Modifications (Exterior/Interior) 17 03-31-2010 03:37 PM
*PICS* of my new lip kit: Seibon CF front lip, Kaminari side skirts and rear lip. PETERPOOP Photo-Video-Media Gallery 19 12-02-2009 10:45 PM
WTB lip kit balmung_chris Cosmetic Modifications (Exterior/Interior) 0 07-03-2009 09:08 AM
