![]() Drives: Yaris 2014 2-Door LE Join Date: Oct 2022
ABS suddenly stopped working in my Yaris 2014 LE Liftback
ABS suddenly stopped working.
I looked up the related fuses from: https://www.autogenius.info/toyota-y...e-box-diagram/ Then I checked my fuses and they looked okay. ![]() What should my next steps be? - I can replaces the fuses regardless. - What else? Thank you in advance. |
Is the check engine light on? Even if it isn’t, I suggest putting a code reader on the ABS 2 port. If you don’t have a reader, you can go to AutoZone or similar, and they will read the codes for you, if there are any.
Don’t worry about driving your car. ABS has not been statistically significant in reducing accidents. As long as nothing is wrong with the brakes themselves, you should be fine. they are components that can fail on the ABS systems on older vehicles that would be prohibitively expensive to repair or replace. It’s very common on older vehicles when ABS fails to just do without it
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
ABS Wheel speed sensor maybe? Hook up a code reader too it that is capable of pulling ABS codes and take a look.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
| Tags |
| abs, fuse |
| 2014 yaris bought at hertz | jstert | Third Gen Yaris General Discussion | 9 | 05-21-2016 06:13 PM |
| 2014 Yaris or 2014 Corolla | yarisse54 | Third Gen Yaris General Discussion | 7 | 06-06-2013 12:44 AM |
