Old 06-05-2023, 12:55 PM   #1
3l3ven
Drives: Yaris 1.3 2006
Fuel leaking
Dear experts,
my wife has a XP9F, 2SZD Yaris from 2006.
Last year in summer the fuel started dripping from the neck of the fuel filler pipe when we top off the tank. At that time were a few small jerking as we realized later.
A technician replaced the fuel filler pipe. After we fill the tank full again it was dripping again.
Because of a reason we went to another technician. But that time the engine has started jerking more often, even stopping when it was idling and the fuel was still dripping. The weather was hot. Around 30-33 Celsius.
So the technician replaced the carbon filter in the fuel system. But by then it was autumn.
Everything seemed fine till this year end of April, when the leaking started again. And there was a slight feeling about the engine jerking.
A holey pipe was found and replaced by the technician. After that and a fuel top off, the car is rolling like it would had cube wheels. Now there is no visible leaking just a very strong fuel smell.
As it seems to loose the fuel cap helps a little.
I would like to ask, has anyone experience like this? Where should we look?
Thank you very much!
3l3ven is offline   Reply With Quote
Old 06-05-2023, 02:44 PM   #2
sh0rtlife
sounds like hydro lock, evap purge valve would be the first thing i would replace
Old 06-07-2023, 02:04 AM   #3
IndestructibleYaris
I would do diagnostics by looking at where it's leaking before wasting money guessing which part it might be
IndestructibleYaris is offline   Reply With Quote
Old 06-07-2023, 11:56 AM   #4
3l3ven
Thanks for both of you!
The plan was, today going go the repair shop. But it was cancelled becasue the weather is cold here and this beauty does not presents the problem for days. The problem comes only when it's hot outside and the Sun is shining. And the tank is above half. There is no any error code in the ECU. At least I cannot see any.
fuel leaking
Fuel leaking and engine jerking 3l3ven Europe (continental) 0 05-30-2023 02:15 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
