Old 11-14-2021, 09:38 AM   #1
phpist
Drives: Yaris III
Camera wiring question with Yaris 2015 (XP13)
Hello,
I replaced my original radio and found one 24pin unused plug inside front panel. It is connected with 4 cables: white, black, red, grey.
Might it be used for rear camera? If so, where do it goes on the other end?
I also found spare 5pin plug inside rear doors near camera hole. It is connected with 3 cables: light blue, black and light brown.
Could there be a chance to reuse some wiring to install rear camera, or custom wiring is required for it?
phpist is offline   Reply With Quote
Old 01-06-2022, 04:58 PM   #2
andrewsweet4
Drives: Yaris 2015
Hello
The 3 pin connector on the back hatch is not for the camera. It is for the optional key switch to lock/unlock the car in some models. Mine also didn't have the camera option installed from the factory. The 24 pin plug with the camera connections from the head unit goes to a blank/ unused connector on the driver's side footwell/door area (left hand drive vechicle) and ends there. The factory didn't fit the harness from that point on to the boot area.
Hope that helped.
andrewsweet4 is offline   Reply With Quote
Old 08-21-2023, 02:17 PM   #3
phpist
Drives: Yaris III
Originally Posted by andrewsweet4 View Post
Hello
Hope that helped.
Hello,
Could you specify exact blank connector located at the door area? How it could be identified?
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
