Old 06-04-2006, 09:03 PM   #19
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Rear 6X9s are straight forward. After taking off the rear deck, four 10mm bolts hold each factory speaker. You'll have to drill your own bolt holes, the factory speaker bolt pattern are wider. Depth is not an issue at all.
Bones is offline   Reply With Quote
Old 06-04-2006, 09:43 PM   #20
JaiTomato
JaiTomato's Avatar
Drives: 07 sedan-flint mica, 96VFR750
[QUOTE=Sp33dY]Are they 10s or 12s" Polk Audios? You have a sedan, right?
This is where the parts came from
http://www.cardomain.com/ride/359220
I'm gonna miss the Focus
JaiTomato is offline   Reply With Quote
Old 06-05-2006, 08:15 AM   #21
punch
punch's Avatar
thanks guys!!!
punch is offline   Reply With Quote
Old 06-05-2006, 09:02 AM   #22
punch
punch's Avatar
couple more questions, the echo kit, how satisfied are you with the fit?? and gaps, any closer pictures of the unit installed??
did you also buy a wiring adaptor?? if so which one, thanks
Old 06-07-2006, 08:33 AM   #23
punch
punch's Avatar
Originally Posted by JaiTomato
Here is a picture with all the panels off and a trial placement of the Alpine headunit. The closest trim kit I could find is from Metra for the Echo/Celica. I also needed an antenna adapter.
in the first pic, any ideas what that large cut-out in the grey plastic(cirle)next to your radio would be for?? maybe for the start button the UK version get??
Old 06-14-2006, 05:45 AM   #24
yarislover
BUY ONE DON'T STARE
Drives: 07yaris liftback
I used the same kit in my 07 liftback and only used about 25% of the mounting hardware. I had to use the original and the trim kit mounts together not easy but the finish looks great. Do you or anyone know the exact speaker size front and back?
yarislover is offline   Reply With Quote
Old 06-15-2006, 01:01 PM   #25
bnorrish
According to Crutchfield, the front speakers are 5 1/4 and ther backs are 6 x 9.
Also, www.scosche.com says they are working on a Yaris install kit but they do not have an ETA.
JaiTomatos fit looks great so it may make sense to go that route instead of waiting.
bnorrish is offline   Reply With Quote
Old 06-16-2006, 12:31 PM   #26
JaiTomato
JaiTomato's Avatar
Sorry guys. I haven't been able to keep up with your questions.
1) I had to trim a little bit of material from the rear of the echo trim kit so it can fit. Otherwise, it covers the vacant spaces perfectly.
2) I got one of the wiring harnesses (for Toyota). There is supposed to be an Alpine wiring to match the Toyota harness, but I couldn't find it so I just ended up soddering the wires together.
3) The front speakers are 6 1/2. Even though..you still need to get a speaker bracket/adapter as shown in the previous photos.
4) The rear seems to be bigger than 6x9's. So drilling and adapters are needed. This I'll do later when funds are available.
4) The subs are Polk 10" and their thump thump is loud enough for me. I have it set only at setting one at the head unit. With the box in, I can still put in one large luggage or two smaller ones snuggly. One guitar can fit also.
Old 07-03-2006, 02:30 AM   #27
Alexandre2k3
Drives: Yaris liftback
Sup all, Just put in a pair of alpine type s in my white HB, it was easy and I didn't need any speaker adapters. I just gutted the inside of the stock ones and used the top of the stock speaker to mount new ones on, just used small screws and screwed them on to top.
Alexandre2k3 is offline   Reply With Quote
Old 07-06-2006, 02:50 PM   #28
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Do you recall the depth on the 6.5"'s? What model are they?
Old 07-07-2006, 05:45 PM   #29
whitehotmr2
Drives: Yaris 2006 Hatch
Deck harness?
Can you tell me if you also used the radio Harness kit for your deck or did you splice into the wires? If so do you have a wiring diagram?
whitehotmr2 is offline   Reply With Quote
Old 07-07-2006, 10:10 PM   #30
punch
punch's Avatar
just buy a wire harness, easy to go back to stock down the road...i bought mine of ebay for $7.00
Old 07-07-2006, 11:44 PM   #31
Bones
Bones's Avatar
***Big Plug***
Radio 12Volts = Blue
Radio Ground = White/Black
Radio Ignition = Gray
Radio Illumination = Green
Left Front Speaker = Pink (+), Purple (-)
Right Front Speaker = Gray (+), Yellow (-)
***Small Plug***
Left Rear Speaker = Black (+), Yellow (-)
Right Rear Speaker = Red (+), White (-)
Make sure you check all wires with a meter.
Old 07-09-2006, 08:10 AM   #32
JaiTomato
JaiTomato's Avatar
Here's the diagram I used http://installdr.com/Harnesses/Toyota-Wiring.pdf
Old 07-17-2006, 10:22 PM   #33
IZAMUPR
BioHazard
IZAMUPR's Avatar
Drives: Yaris Sedan Blazing Blue
ppl, i am new here, i just have 1 moth w my Sedan yaris,
i have an question , i am seeing all bout the center console( great stuff) and the doors spk, but what about the rear spk, they come w speaker bracket integrated,w/ the spk, plz post some pics, and instrucions to how, upgrade this part. thx and I LOVE MY YARIS.
IZAMUPR is offline   Reply With Quote
Old 07-17-2006, 10:27 PM   #34
fnkngrv
fnkngrv's Avatar
I have a hard copy of how to install the rear speakers and the front...I am going to scan them in at work tomorrow and then figure out a way to place them here...can someone host the doc for us if I email it?
Old 07-18-2006, 03:18 PM   #35
ChinoCharles
Drives: LB
Yeah, I can host it. Just e-mail it to me. charlesluzar@hotmail.com
I'll put it up when I get home from work tonight if its in my box at http://www.luxlightandland.com/yarisworld.
Old 07-18-2006, 03:28 PM   #36
fnkngrv
fnkngrv's Avatar
I woke up late this morning and was not able to pack the docs...I am sorry...I will have to see about taking care of it tomorrow...I am having driver issues with my scanner at home.
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 01:58 PM
Security upgrade Ryu General Yaris / Vitz Discussion 7 05-09-2006 10:00 PM
security upgrade? got615 General Yaris / Vitz Discussion 4 04-27-2006 10:50 AM
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 11:33 PM
Factory Stereo and Audio kralmrax In Car Entertainment + Electronics (audio / video / alarm) 2 01-14-2006 02:06 AM
