Old 11-07-2024, 08:21 PM   #1
nikonNUT
Drives: 2010 3 Door L
Clock Spring Failure?
Good evening all,
Had an odd issue and need some advice. Probably 8 years ago I ordered a cruise control kit from CT Scot and installed it. Absolute breeze and have been happy ever since until about a week ago. Started have an issue where sometime the cruise would arm and work fine and other times where it would not. It finally quit turning on at all 2 days ago. Figured I would grab a new stalk and swap it out and all would be well. NOPE! As a real head scratcher the norn works and no airbag warning lights but the cruise still won't arm unless... I turn the steering wheel all the way to the right or all the way to left. Then I can turn it on but I can't set it. I want to say clock spring but with the horn working is that possible? I mean I guess the horn, just completing a circuit, might still work while the resistance of the cruise stalk could cause issues but I wanted to ask people smarter than me! Thank you for the help and I look forward to hearing your thoughts!
"Sanity? What would I do with something as useless as that?”
nikonNUT is offline   Reply With Quote
Old 11-07-2024, 09:23 PM   #2
nikonNUT
UPDATE : Don't know why but it started working and I'm not asking why!!!
Old 11-08-2024, 06:27 AM   #3
BLH
Drives: 2007 Yaris Sedan
There was a recall for the 2007 Yaris on the clock spring.
So they can fail.
I don't have any data on how often it happens or if some year models are more prone to failure.
BLH is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Clock Spring ohnodarlin Willing to Buy by private party 0 01-08-2013 03:34 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
