#37 |
![]() Drives: 2009 5dr hatchback Join Date: Jun 2010
Will an 08 headlight fit an 09?
#38 |
^ No. Front and rear bumpers changed in '09+, the headlights are not compatible at all, and older tails stick out on an '09+ bumper.
See here for pics of 2008 tails on a 2009 model Yaris: http://www.microimageonline.com/foru...008+tails+2009
#39 |
I ordered the front two headlights from logical-source.com for an 09 model and the shipment came in today. It was an 08 model with additional mounting holes to match the newer model. Should I even attempt to see if it fits or return it?
#40 |
#41 |
Noel_Malta
Drives: 2010 5-Door hatchback 1.3L Join Date: Feb 2012
will a front bumper add-on lip from the 2008 model fit on a 2010 bumper version?
#42 |
![]() ![]() Drives: Yaris Join Date: Oct 2017
I can’t tell the difference between the two headlights?
I need a new bumper and was considering the 2009 for my 07. |
#43 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
I'm pretty sure the 09+ Yaris headlights were the same shape as the previous years but they added DRLs. The Tail lights on the LB are slightly different on the 09+ models. If you put the 07 tail lights (For example the RS lights) on the 09+ models they will sort of hang over the bumper towards the hatch.
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
The inside edge of pre'09 headlights are a straight line front to back. '09 to '11 curve inward slightly mid point.
#45 |
![]() ![]() Drives: 2010 Hatchback Join Date: Oct 2016
![]() Tried a pre 2009 headlight on a 2009+ Yaris. Different headlights. Doesn't fit, notice the bumper curve and hitting the headlight. ![]() 2009+ has a slight curve near bottom of headlight. ![]() Pre 2009 on left. Post 2009 on right. |
#46 |
![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
Good info! Now we know we also need headlights if we want to install a post 09 front bumper on a pre 09 car... The post 09 RS bumpers are very appealing to me.
#47 |
yup, JDM late08-early10 RS bumpers are the best
#48 |
![]() Drives: none Join Date: Jun 2021
Thanks for info!
#49 |
![]() Drives: Mazda Join Date: Nov 2021
#50 |
im going to bump and old sticky and HOPE someone can 110% verify
to be clear.. the 05-07 vs 09-11 hood is 100% the same? what about the 05-07 vs 09-11 hatch? i assume 3dr and 5dr use the same hatch? i may have found a source thats still making the hatches and hoods in CF for about 300$, so i want to be dead nuts sure before i pull the trigger, im looking for weight savings only..and the parts WILL GET PAINTED...found front doors too but 1200 for a pair is painfull |
#52 | |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
But did they bolt in?
I have always wanted Projectors on my 2010, but they only come 07/08 Style... Wife Whacked a Deer, so full 2008 nose will be going on the car, I realize the lower bumper "support/push bar" is also likely different, but I need to know if there is anything to do with mounting 2008 lights on the 2010 that is different? Or will I have to change the upper radiator support or whatever?
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
#53 |
2008 bumper covers and headlights are direct bolt on to a 2010. Rad supports, crash bars, tow hook location are all the same.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Body kits for a 2009? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 63 | 03-10-2016 07:47 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 09:52 PM |
| 2009 Sedan Aerokit Front Lip Part #? | Split | Cosmetic Modifications (Exterior/Interior) | 9 | 11-26-2008 08:19 PM |
