Old 09-25-2006, 06:12 PM   #1
Yaris Dick
Drives: 07 Yaris LB, 06 VW GTI, 06 G6
Synthetic oil MPG boost since change
Just checked MPG on my first tankfull since my first oil change and switch to Amsoil 5W30.
Went from 40.4 to 42.4 MPG hwy. 5% increase. Not too shabby.
Yaris Dick is offline   Reply With Quote
Old 09-25-2006, 06:42 PM   #2
foober
Drives: two yaris liftbacks
I just ordered a 12 pack of 5W/30 amsoil oil and 3 amsoil oil filters. The oil filter part number is #EaO09.
Thanks to all that turned me on to amsoil. Everything i've read is its the best right now in synthetic oil.
foober is offline   Reply With Quote
Old 09-26-2006, 11:43 AM   #3
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
You just can't go wrong with Synthetic Oil! I can't wait to change over on my first oil change! 5% is pretty remarkable, just by switching oil. I will be using Series 2000 0W-30. Any reason y'all went with 5W-30? Just curious...
nsmitchell is offline   Reply With Quote
Old 09-26-2006, 01:08 PM   #4
foober
From what I've read the 0w-30 is a bit better in colder temperatures. Since I live in montana I'll use that in the winter. But I'll use 5w-30 otherwise. Considering i'll also be using the amsoil oil filter i shouldn't have to change my oil but once a year. I probably only drive around 10,000 miles a year with my yaris. So i'll probably only use the 0w-30. Guess I'll use the 12 pack of 5w-30 Amsoil oil I also got in my trucks.
Old 09-26-2006, 01:22 PM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Overall the 0w-30 is the better oil and lasts longer between oil changed due to higher level of Base stocks.
The 5w-30 is still an awesome full synthetic but cheaper in price
I run the 0w-30 and change the wix filters every 6 months.
I get over 40mpg
That's with an automatic
Manual owners should run Amsoil 75w-90 severe gear oil in the transmissions. Automatic owners should run Amsoil ATF
do this and you will see another increase in mileage.
With my truck after my complete tune up I went up to about 22 MPG hwy and 18 in town
changed the engine oil to Amsoil 0W-30
changed the ATF to Amsoil ATF
Changed the rear differential fluid with Amsoil 75W-90
My mileage went up to 27mph hwy. 24 mixed, 22 in town
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 09-26-2006, 01:34 PM   #6
GoZO
Drives: Yaris 3 Door
How often to you plan on changing oil/filter?
GoZO is offline   Reply With Quote
Old 09-26-2006, 04:40 PM   #7
YamilR
YamilR's Avatar
Oil
Is this the oil that you got? https://www.amsoil.com/storefront/xlf.aspx
Old 09-26-2006, 05:08 PM   #8
Yaris Dick
No. I got the ASL 100% Synthetic 5W30
Old 09-26-2006, 05:09 PM   #9
Yaris Dick
10,000 miles.
Old 09-26-2006, 05:11 PM   #10
Yaris Dick
I went with 5W30 because it's cheaper and I live in the south and I've had prior good results from it, tried the 0W30 once and saw no tangible (measurable) improvement over the 5W30.
Old 09-26-2006, 05:16 PM   #11
YamilR
YamilR's Avatar
How about a link if you don't mind
Old 09-26-2006, 05:21 PM   #12
Yaris Dick
http://www.amsoil.com/storefront/asl.aspx
Old 05-11-2007, 01:00 PM   #13
grampi
Drives: Corolla
How much oil does the Yari take when you do a filter/oil change? Thanks.
grampi is offline   Reply With Quote
Old 05-11-2007, 01:18 PM   #14
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
4 Qtrs
Old 05-11-2007, 02:40 PM   #15
grampi
Drives: Corolla
Originally Posted by CASTREX View Post
4 Qtrs
I'm glad to see Toyota's increased the sump size of the 1.5 liter since the Tercel days. My Daughter's Tercel only holds 3 qts.
Old 05-11-2007, 03:55 PM   #16
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
I too have nothing but respect for Amsoil. My family used it in heavy equipment for years and it performed in a stellar fashion. The procedure was to swap filters, top off and send samples out for analysis. We only changed oil once each year. Unlike cars the intervals where determined by hours ran and not miles. With top notch filters (Amsoil, Wix, Hastings) the average Yari Pilot with an annual 15K useage would only need to change there oil once a year. with a filter swap around 7.5K.
blacksan is offline   Reply With Quote
Old 05-11-2007, 05:25 PM   #17
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Hypermilers change their oil often because fresh oil always nets better MPG's, regular or synthetic.
Old 05-11-2007, 06:44 PM   #18
CASTREX
CASTREX's Avatar
BTW I just received a 12pk of Amsoil 0W-30 on my mail today!
Also got thhe 75w-90 gear oil for the tranny.
Can some one tell me how hard is to change the tranny oil??? Should I go to a shop or is something I can do by my self???
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 11:49 AM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 10:32 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
