Old 05-14-2007, 01:53 PM   #19
LucaItalia83
LucaItalia83's Avatar
Drives: Yaris '07 D4D M-MT
very nice !
NEW YARIS 1.4 D4D -M-MT -90 HP - SILVER GREY - SOL
- 4 PARKING SENSOR -
- BLUETOOTH PLUS -
- AUTOMATIC GEARSHIFT -
LucaItalia83 is offline   Reply With Quote
Old 05-14-2007, 04:31 PM   #20
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Love the Supra, looks sweet!
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 05-14-2007, 06:54 PM   #21
yaris514
Drives: white yaris RS
does anybody know where to buy the vitz emblem for the hood and the liftback door?
yaris514 is offline   Reply With Quote
Old 05-14-2007, 10:24 PM   #22
uncleyaris
sponsor section/ebay
Old 05-15-2007, 12:57 AM   #23
Fred2006
Fred2006's Avatar
Drives: Yaris 06
Is that the intake whit the blitz SuperCharge ???
Where,how,how much, ???
http://fred2006.monchar.com/
Fred2006 is offline   Reply With Quote
Old 05-15-2007, 01:01 AM   #24
ChinoCharles
Drives: LB
Taken from http://en.wikipedia.org/wiki/Throttle_body
In a fuel injection engine, the throttle body is the part of the air intake system that controls the amount of air flowing into the engine, in response to driver input. While the accelerator is often called a "gas pedal", it would be more accurate to describe it as an "air pedal".
The throttle body is usually located between the air filter box and the intake manifold, and usually attached to, or near, the mass airflow sensor.
The largest piece inside the throttle body is the throttle plate, which is a butterfly valve that regulates the airflow.
On many cars, the accelerator pedal motion is communicated through the throttle cable, which activates the throttle linkages, which moves the throttle plate. In cars with electronic throttle control (also known as "drive-by-wire"), an electric motor controls the throttle linkages and the accelerator cable connects not to the throttle body but to a sensor. The Engine Control Unit (ECU) determines the throttle opening.
When the driver presses on the accelerator pedal, the throttle plate opens up, allowing more air into the intake manifold. Either a throttle position sensor or an airflow sensor measures this change and communicates with the ECU. The ECU then increases the amount of fuel being sent to the fuel injectors in order to maintain the desired air-fuel ratio.
Throttle bodies may also contain valves and adjustments to control the minimum airflow during idle. Even in those units that are not "drive-by-wire" there may be a small electric motor that the ECU uses to modify the throttle opening.
Many cars have a single throttle body, however more than one may be used, chained together by linkages, to improve throttle response. At the extreme end, cars such as the BMW M1 have a separate throttle body for each cylinder.
A throttle body is somewhat analogous to the carburetor in a non-injected engine. Carburetors combine the functionality of the throttle body and the fuel injectors into one, that is, to modulate the amount of air flow, and to combine air and gas together. Cars with throttle body injection (called TBI by General Motors and CFI by Ford) locate the fuel injectors in the throttle body, thereby allowing an older engine to be converted from carburetor to fuel injection without altering significantly the engine design.
Its basically like having 4 separate intakes on your car. Crazy stuff.
Old 05-15-2007, 01:09 AM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
Question.... would 4 MAF sensors be needed for the ITB? And you say they have adapted this to a Yaris already?
Old 05-15-2007, 01:16 AM   #26
ChinoCharles
Drives: LB
I'm not sure how the MAF issue is dealt with. I didn't talk to them enough about it to get that far. If anyone is serious about buying it I can give you the e-mail you'll need. They'll know more than I will.
Old 05-15-2007, 01:18 AM   #27
Black Yaris
der Zeck
what were they talkin about cost wise? that will tell me if I will shoot them a line or not
Old 05-15-2007, 01:30 AM   #28
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
wow....
double wow....
You'd use a map sensor instead of maf, and holy hell, how do you expect to supercharge when you'd have an open intake like that?!
I hate to sound rude, but man, you guys need a crash course in cars.
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 05-15-2007, 01:33 AM   #29
Black Yaris
der Zeck
Originally Posted by nebulight View Post
wow....
double wow....
what about cars that have MAP's and MAF's?
and if you look closely there is a MAF on the side of the first Throttle body
Old 05-15-2007, 01:58 AM   #30
nebulight
Novice Hypermiler
You'd just use the MAP, and I'm pretty sure that is a MAP sensor on the side of the throttle body.
Old 05-15-2007, 02:21 AM   #31
Black Yaris
der Zeck
That is a Mass Air Flow on the side, how do I know that? Because I know what it looks like on our cars, and that is not the Manifold Air Pressure... I do see wich side of the throttle body it is on, but it is a MAF on the MAP side... then again the whole ITB thing is over my head
Old 05-15-2007, 11:07 AM   #32
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
Danstoy makes the ITB kit. It will fit the Yaris with slight modification AFAIK.
only danstoy makes it?...does anyone know any other company?
Nagka-anak sina boy at nene, isang lalaki at isang babae. binata't dalaga na sila...
Nene jr.: tay, peram naman ng kotse o...
Boy Bastos: sige pero isang kondisyon. mag-ano muna tayo.
Nene jr.: tay meron ako ngayon e. blowjob na lang kita.
Boy bastos: o sige.
pagkatapos ng blowjob...
Nene jr.: tay, bat lasang tae yung etits nyo?
Boy bastos: ah ganon ba? hiniram kasi ng kuya
mo kanina yung kotse e!
esquiva is offline   Reply With Quote
Old 05-15-2007, 11:17 AM   #33
ChinoCharles
Drives: LB
I can get the mechanical bits of that ITB kit for $1000 a pop with a discount on group buys. The kicker is you have to make the necessary modifications yourself and deal with engine management on top of that. You're probably talking 2 grand when all is said and done tops. That's w/ a standalone, tune, and custom fab included. Not bad for 30-40 reliable HP. Question is will it fit? Second question is will it bolt up? So many questions!
Old 05-15-2007, 11:51 AM   #34
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Originally Posted by kurokoma-kun View Post
nebulight, that is a datsun?
Its a Toyota GT 2000 coupe...only the most coveted Toyota in history.
Datsun only wishes they had created anything at the time that was as cool.
Old 05-15-2007, 12:03 PM   #35
esquiva
Noypi ako!
esquiva's Avatar
hmmm...lets get something going...im interested in providing the test vehicle to make sure it would work on our cars....thats if we could talk to them about something like that...
Boy bastos: o sige.
toyotafest 2007 esquiva California 3 05-14-2007 06:26 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 06:09 PM
2007 Yaris or 1999 Mercedes ClK430 jamal1984 Off-topic / Other Cars / Everything else Discussions 9 03-19-2007 09:27 PM
2007 Registration and Insurance Vitz-to General Yaris / Vitz Discussion 21 03-28-2006 09:57 PM
