![]() Drives: 07 LB MM 5spd, 99 M Coupe Join Date: Apr 2007
n00b suspension install question
If I'm going to install Tein S Springs + TRD Shocks, do I need (aside from tools listed in DIY sticky):
1, Spring compressor? 2, Reuse stock bump stop? 3, What else do I need? Thanks in advance guys! |
![]() ![]() ![]() ![]() Drives: 07 Yaris LB Absolute RED Join Date: Apr 2007
i installed my s techs with the same bump stops but i used the stock shocks.... and yes you will need a spring compressor for the stock spring... i bought a set from my local automotive store and returned it the next day....
and third some beers and a nice sunny day |
add a good pizza and some sweaty hot chicks to pass you the tools.
but besides that you will need a spring compressor to switch over the top mount plates. you can either rent them or buy/return it if you don't plan on using it again. |
when we installed mine (same set up), we didn't need to use spring compressors. and we cut the bump stop like how Chris did.
heh, get ready for a stiff ride (although i wish it is a tad bit stiffer). |
cool, all i need now is about 50 hot chicks to pass me tools
thanks guys! |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
im also getting ready this saturday to install the same setup. CHRIS or someone else can you tell me how much you cut your bumpstops and do i really need to if i use the stock struts.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
Your Toyota Technician
wacky broadway nightmare
Drives: Willow is a '07 Red Yaris LB Join Date: Apr 2007
stupid boys with your tools.
i STILL haven't gotten my Yari lowered. good luck Stig
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
![]() Seriously I have a question about the spring compressor... is it completely safe to use at home? Something about handling the spring while its tensioned freaks me out... |
TRIM HUNTER
THIS IS GOOD FOR BOTH THE TRD AND STOCK STRUTS????
#11 | |
death: i'm mechanically challenged...however, i got some mad lego skillz...reading a couple of DIYs got me think that this is just a full size lego set....yeah, i need lots of luck here
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Myself I wouldn't cut them for the stock struts...they are designed to keep the strut cylinder from bottoming out. The bump stop bottoming is much softer and less damaging that having the cylinder bottom out. Aftermarket struts are probably different, but I can't imagine any car manufacturer engineering their products with more clearance than needed....it usually costs money!
Has anyone actually checked how far down the strut can go, with and without the bump stops....would be easy to do with the spring off. Then you could tell how much distance the bump stop has to compress before the cylinder bottoms. Of course then you'd have to decide how much you think the bump stop would compress under a severe load. No matter what...the longer the bump stop is the softer the 'thump' will be when it hits.
____________ Old School Cobble Jockey
or some huge guy named Hans to compress the spring for you
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
my friend put spings in his mazda prog... and they used 4 ppl holding the spring down lol in his front lawn
"It hurts more when its wet" |
#15 |
Usually however far you drop it say its an inch then you cut an inch off the bump stop. I believe that is the rule of thumb. Double check Chris's DIY for sure.
#16 |
I cut ribs down on the bump stop don't notice much rub at all. There a couple pot holes on my way to work that will bottom me out but they are quite large so I just do my best avoid them. :)
#17 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
When I installed my Tein springs on my xB, I didn't need a compressor for the rear; I just unbolted the shocks, and the springs eventually popped right out. The front struts didn't need compressors, as they weren't under much load at all. Do the Yaris front struts need compressors?
Subcompact Culture: The Small car blog |
#18 |
yes i beleive its the same set up as the xb
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| question about radio install | misfits9095 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 06-06-2007 03:08 PM |
| NorCal: Suspension install | The Stig | California | 12 | 06-05-2007 12:51 AM |
| Suspension Setup Question | Ran Kizama | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 27 | 04-28-2007 02:05 PM |
| n00b question... | djfuji | Cosmetic Modifications (Exterior/Interior) | 9 | 01-29-2007 10:47 PM |
